11 registered (redmorgan, asbojohn, Vitruvius, Soleng, mr_tony, deanroyal, Andrewr, Budster, NAC, Eddie Cairns, Martyn Culling), 50 Guests and 2 Spiders online.
James Bond????
Recent outing in Bretagne
Winter Sun
Accelerator
Morgans on Google Street View
new member checking in
by ricks67m
Today at 03:22 PM
Good news for Saab
by David of SW19
Today at 09:03 AM
What production number is your Morgan 3-wheeler?
by Aeroman
Today at 08:31 AM
Le Mans Classic Laps
by philrs
Yesterday at 08:53 PM
hood change for 2012 model year
by SFO
Yesterday at 07:49 PM
M3W SS
by PaulJ
Yesterday at 05:19 PM
Please help: Doreen's Story
by Trevor
Yesterday at 10:52 AM
jbk, Barmar, ricks67m, geoffdragon, threewheeler
2088 Registered Users
2088 Members
48 Forums
7275 Topics
Max Online: 150 @ 07/04/11 03:44 AM
February
M Tu W Th F Sa Su
1 2 3 4 5
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29
#41468 - 09/03/10 08:33 PM Engine oil change for 1988 +8 3500 efi (pre-cat)
Wyndales Offline
Loc: Biggar, Scotland
First time to service "new" car before getting many miles on as warm weather approaches, so please can I have advice on preferred oil viscosity (hopefully 15:40 'cause that's what I bought)and tips on emptying and re-fill process (filter change first or afterwards?) to avoid any risk of no oil pressure after change
Many thanks - John
John Rutherford (1988 +8)
#41509 - 10/03/10 04:57 PM Re: Engine oil change for 1988 +8 3500 efi (pre-cat) [Re: Wyndales]
smiffmog Offline
Loc: northants, uk
Hi John, I have been investigating the very same issue and stumbled across www.gomog.com albeit an American site, it effectively contains an on line workshop manual for the +8 along with other models. It covers in quite detail the procedure for changing the oil and priming the system. Hope it helps. Steve
#41516 - 10/03/10 06:26 PM Re: Engine oil change for 1988 +8 3500 efi (pre-cat) [Re: Wyndales]
Wyndales Offline
Thanks Steve; I'm going to use Castrol magnated 15w40, it's semi-synthetic but spec suggests it should be ideal
yes, i'm a fan of GoMog already, it was brilliant for my much older Plus-4
Let me know how you get on with your oil change and any tips you can pass on will be greatly appreciated
kind regards
John
#41525 - 10/03/10 08:54 PM Re: Engine oil change for 1988 +8 3500 efi (pre-cat) [Re: Wyndales]
DaveW Offline
Loc: Yorkshire
15/40 Magnatec should be fine. I used that 'later on' in my 3.5V8 (in an MGB)but for many years used Valvoline 20/50. I never had 'no pressure' after an oil change, but always filled the new filter before fitting. It reduces the time delay before pressure builds up, and this is relevant for all engines with a hung filter.
Red Roadster
#41543 - 11/03/10 11:33 AM Re: Engine oil change for 1988 +8 3500 efi (pre-cat) [Re: DaveW]
Vampirex Offline
Loc: Normandy, France
Hi,
On a Plus 8, you have to be very careful because the oil pump can be deactivated if it becomes empty (even partially), it is a very well known problem on the Rover V8/Buick 215.
I always fill up the new filter with fresh oil, then remove old filter, and immediately screw the new one. With this method didn't have any problem. I use Motul 300V Competition 15w50, one of the best full synthetic oil. I had it analysed by a private laboratory and found that it had the corect level of ZDDP for these engines.
BR
Daniel.
