11 registered members (+8Rich, Jon G4LJW, HJP, dmh, Knoxxy, sewin, Rog G, BARDI1949, Ncik P, Laurens, RJW),
331
guests, and 10
spiders. |
Treacle
by BobtheTrain. 03/06/23 01:04 PM
Forums32
Topics45,151
Posts764,716
Members8,359
Most Online1,033 Dec 28th, 2019
Re: Battery Replacement?
[Re: Herrie]
#772867
28/03/23 02:25 AM
28/03/23 02:25 AM
Posts: 253 Las Vegas
JohnMat
Las Vegas
Thanks Herrie. It all makes sense. My only concern would be that I believe the maximum current density for copper is 95 A/mm2, so if you want to fully run the starter from the capacitors and not just augment the battery, then your 1.5 mm2 cables are under-sized. But if the battery is dead this won't work anyway!
2020 M3W
[Re: KenShapiro]
#772937
28/03/23 05:03 PM
28/03/23 05:03 PM
JohnMat
Las Vegas
Hi Herrie - I think you are calculating current assuming the voltage drop across the wire is 12V. At 35 kA you would be dissipating 420 kW in a 3cm wire, so it would not last long, not that it matters here as we are talking about much lower currents. I think in practice there are three considerations for wire size: 1. The maximum power you can dissipate in the wire before heat problems arise, commonly referred to as ampacity for steady state. Given the short duty cycles here, it may not be a concern. 2. The maximum voltage drop you can stand due to the resistance of the wire. If you use, say, a 0.25V drop in each wire as your target, you should use 0.25V instead of 12V in your math above, so the limit is 48x lower. 3. The electro migration limits of the copper itself. I thought that was the 95 A/mm2 I quoted, but on further googling the actual limit seems to be 10^4 to 10^5 A/mm^2, so not a concern. Please correct me if I'm wrong.
2020 M3W
[Re: KenShapiro]
#772986
29/03/23 01:35 AM
29/03/23 01:35 AM
JohnMat
Las Vegas
Hi Herrie - I think your solution is sound, and the physics check out. I disagree with some of your math, but it doesn't really matter if it works, and I agree it will!
2020 M3W
[Re: KenShapiro]
#773004
29/03/23 08:55 AM
29/03/23 08:55 AM
Posts: 6,109 East Harling, Norfolk UK
I suspect it works because the energy stored in capacitors is transferred at a moderate rate to the battery before the starter is operated, effectively giving the latter a small top up surface charge. This assumes an adequate voltage difference.
2018 Roadster - Red/Magnolia - Morton 1966 Land Rover S2a 88 - Lenny 1945 Moto Guzzi Airone
