1 registered members (C2RM),
130
guests, and 10
spiders. |
Topics44,631
Posts754,982
Members8,264
Most Online1,033 Dec 28th, 2019
Re: Indicator switch
[Re: richardsanders]
#758967
21/10/22 03:47 PM
21/10/22 03:47 PM
Posts: 11,071 Gloucestershire, UK
Hamwich
Scruffy Oik
Scruffy Oik
Gloucestershire, UK
The original Morgan column switch came from a Triumph Herald IIRC, but a standard one won't fit, you need to put an S bend into the shaft. This is a pretty fraught exercise, since (1) they are quite expensive and (2) there's a danger of kinking the tube.
I've done it twice now, I wrapped the stem in spiral banding to protect it and used the jaws of my bench vice to brace it whilst I put the bends in.
Tim H. 1986 4/4 VVTi Sport, 2002 LR Defender, 2022 Mini Cooper SE
#758969
21/10/22 04:16 PM
21/10/22 04:16 PM
Posts: 4,849 Northants, UK
TBM
Northants, UK
I think it was Ford Transit, but any BL one can be made to fit (I have one from an Austin Mini). However, I'm not sure how they'd fit on a '69 which has the indicator on a dash toggle switch I think.
You may have to bite the bullet and fettle the dash to make it fit. Column switches are so much easier - I've added a wiper column switch to mine as well.
1972 4/4 4 seater - 3G Morganeer Too many ratty motorbikes
#758971
21/10/22 04:33 PM
21/10/22 04:33 PM
Posts: 557 Bethel, CT USA
PaulyG
Bethel, CT USA
This is the Welcome Forum.
You should post this in Classic Morgans Forum. You'll get more replies there.
1973 4/4 2 place
#759001
21/10/22 10:25 PM
21/10/22 10:25 PM
Posts: 2,142 Wales
Taffmog
Original was Ford Transit, MkII Cortina may be similar too but not sure.
1969 4/4 1995 plus 8 2002 Aero S1 2013 M3W 2014 Plus 8
#759005
22/10/22 07:16 AM
22/10/22 07:16 AM
richardsanders
#759044
22/10/22 03:02 PM
22/10/22 03:02 PM
Posts: 167 Yorkshire
Jack & Jill 602
Yorkshire
I suggest that you have a look in the Car Builders Solutions catalogue, lots to choose from.
Jack 1985 4/4 T/C 4 seater Royal Ivory 2018 Pembleton SuperSport (self built). Siva Edwardian
[Re: Hamwich]
#759058
22/10/22 05:57 PM
22/10/22 05:57 PM
Arwyn Williams
I've done it twice now, I wrapped the stem in spiral banding to protect it and used the jaws of my bench vice to brace it whilst I put the bends in. Switch is courtesy of Ford Transit Mk1, Ford Corsair and a version of the Bedford CF. If you know where to look and the right part numbers you can pick them up for less than 20 quid Arwyn
