10 registered members (Craig Jezz, John Winn, t50, Stephen Beckett, esse16, Ian Wegg, Camelot, RichardV6, Gambalunga, JoeSpeetjens),
113
guests, and 5
spiders. |
Forums32
Topics45,154
Posts764,751
Members8,359
Most Online1,033 Dec 28th, 2019
Re: Fixing oil pressure and temperature
[Re: GLLOQ]
#774275
10/04/23 09:16 AM
10/04/23 09:16 AM
Posts: 6,112 East Harling, Norfolk UK
That was my understanding Ian. Clearly the pressure side of gerotor oil pump can only slow the head of oil from tank creeping back into sump over time. Not an issue if your M3W is used fairly regularly though.
2018 Roadster - Red/Magnolia - Morton 1966 Land Rover S2a 88 - Lenny 1945 Moto Guzzi Airone
[Re: GLLOQ]
#775414
22/04/23 08:31 PM
22/04/23 08:31 PM
Posts: 1,744 New River Valley, VA
rcmatt
iso over the winter, mine sat. drained at least 2 quarts out the bottom. well, I say 2 quarts, I only had a one quart pan....
Rodger 2018 M3W "Dreamers on the Rise" 2004 Plus 8 (wife's) old Goldwings and a couple of Harleys
[Re: rcmatt]
#775478
23/04/23 10:11 AM
23/04/23 10:11 AM
Posts: 681 Grindelwald Switzerland
Laurens
iso over the winter, mine sat. drained at least 2 quarts out the bottom. well, I say 2 quarts, I only had a one quart pan....  A check in the tank before is something not to forget
[Re: GLLOQ]
#775510
23/04/23 03:53 PM
23/04/23 03:53 PM
Posts: 3,754 Port Orchard, WA.
LightSpeed
Port Orchard, WA.
Mine drains quite a bit if sitting very long and as long as it is not on the floor then it is in the engine and I let it idle to pump it back into the tank before I drive it.
The light at the end of the tunnel is actually a train. 2019 M3W
[Re: LightSpeed]
#775517
23/04/23 05:34 PM
23/04/23 05:34 PM
rcmatt
what I found was I was getting a lot of start up smoke and also having to add oil. I wonder if for a long sit (e.g. winter) of maybe just draining the oil completely and then adding it back before start up. Much easier to drain the tank, than getting to the sump plug
