12 registered (Fjemog, AJSki2fly, Ghostcheese, andreasmeul, PaulJ, DaveW, Gajet, jbk, A11OGE, asbojohn, Neilda, RedThree), 16 Guests and 9 Spiders online.
Little and Large
Grand Day Out
Mog meets Mog
National Motor Heritage Day
I believe the same could be said of Classic Cars
by A11OGE
21/05/13 10:35 AM
+4's with Ecotec swap, a question for you
by flaagan
21/05/13 09:24 AM
Rare Astons - Old and New
by Clipper
21/05/13 07:26 AM
New Member with M3W
by rickmazer
20/05/13 10:44 PM
Prescott photos - with a bit of luck!
by sospan
20/05/13 08:21 PM
Spares for a long trip
by CJB
20/05/13 05:06 PM
Any other M3W forums out there?
by Crowbar
20/05/13 05:04 PM
gobel, Mats, davewhite, sailingmad, rickmazer
2863 Registered Users
2863 Members
51 Forums
11037 Topics
Page 2 of 2 < 1 2
#93914 - 29/05/12 07:41 AM Re: Daft Coolant Question [Re: Richard - Aus]
Graham, G4FUJ Offline
Loc: Cheltenham, GLos. UK
Yes, they can.
I would do as Meabh suggested and plumb your radiator overflow into an overflow bottle / tank.
I used to have a plastic tank on the inner wing, but when that expired a year or so ago, I fitted an old brass tank from a Land Rover / Range Rover (it was lying in the shed - might as well use it!) mounted on the passenger side of the bulkhead. I see Peter Mulberry (Mulfab) make stainless ones.
At one stage my system was pressurized to the expansion tank (plastic, which probably helped cause its demise). Now I have the pressure cap on the radiator, with a plain cap on the bottle. The overflow from the metal tank runs down the front of the bulkhead should it ever be needed, just to keep antifreeze off the paintwork.
Cheers,
'01 Freelander TD4; '90 Defender 90 SW
#93915 - 29/05/12 07:55 AM Re: Daft Coolant Question [Re: Graham, G4FUJ]
tmg513 Offline
Loc: Powick
http://www.team.net/www/morgan/tech/cooling/art020.html
Graham and the poster who said about the top of the radiator being the expansion area are dead right. The article above explains all.
1972 4/4 2 Seater
2008 Triumph Sprint ST 1050
#93920 - 29/05/12 08:14 AM Re: Daft Coolant Question [Re: Graham, G4FUJ]
Dean-Royal Offline
Loc: UK (up north)
Originally Posted By: Graham, G4FUJ
Yes, they can.
Cheers,
+1 G thumbs
33 MAX v SPIDERMAN
#93943 - 29/05/12 12:29 PM Re: Daft Coolant Question [Re: Dean-Royal]
Martyn Culling Offline
Loc: Snorbans, UK
Article makes sense.
A plain bottle does work, but those with a long memory will recall my arguments in the letters page of Miscellany as not everyone believes it.
But a far better solution is to do what Graham and I have both done, put a proper expansion tank on the bulkhead, the pressure cap on that, and a plain cap on the radiator. I've also got an uprated radiator (more cores) and have reduced the pressure from 15 to 9 psi as high pressures leak eventually.
My tank is a Sherpa van item kept by a keen scrapyard I used to frequent as it was brass. I think they kept it because of the metal value, but to me, it was easily soldered to make the adaptations needed to fit a Morgan. The Range Rover item bolts straight in, but you try finding one. Graham was lucky with his shed!
1930 Super Sport Aero 'The Elk'
#93955 - 29/05/12 02:13 PM Re: Daft Coolant Question [Re: Martyn Culling]
GLLHG Offline
South Wales Correspondent
Loc: South Wales UK
Don't know if anyone is interested but I fitted a Mulberry expansion tank to my 4/4 Zetec ( Ok, being me I did have a gripe and it was that I then had to get it polished myself!)
Also, becuase the pipes to and from rad to Ex Tank ran very close to the engine I fitted Goodridge braidedd hoses for extra safety
I use this with plain cap on the rad and expansion cap on the tank
There was nothing amiss with the OE metal ( brass) item I took off ( Range Rover/Land Rover) In fact it was in excellent 'nick' but I just wanted to smarten up the engine bay. I left that tank at Mike D's ( only a few months ago) so he may still have it if anyone is interested
Cheers
GLLHG
#94433 - 03/06/12 05:55 AM Re: Daft Coolant Question [Re: GLLHG]
Richard - Aus Offline
Loc: Perth, WA, Australia
Hi there and thanks for all for your input.
So if I understand things as I have a pressure cap I am OK as is (i.e. filled right up); however going forward it would be better to fit a expansion tank. Something ultimately like this.
Can this work with my current radiator cap, i.e. would it allow return of the fluid to the system or will I need a new radiator cap? I notice MR sells a kit click here.
Can the expansion tank be fitted anywhere? Or does it have to be at a certain level (I am thinking syphoning issues??).
Thanks as ever,
R.
#94437 - 03/06/12 06:52 AM Re: Daft Coolant Question [Re: Richard - Aus]
£85 for an expansion tank kit? shocked2
Make your own, along the lines of what Tim has done, shown in your first link.
Better to keep the tank at a reasonable height compared to the rad. You can continue to use your present rad cap.
Cheers,
#94438 - 03/06/12 06:54 AM Re: Daft Coolant Question [Re: Graham, G4FUJ]
Great and sounds like a plan - I did think it a little pricey!
Page 2 of 2 < 1 2
