10 registered (lotusien, petemog, Dean-Royal, JBu1, lord-richfield, Quicksilver, Dave Turner, Easter, Gin, 4/4sportsfun), 21 Guests and 14 Spiders online.
Fiat Millecento TV
One week old
WJ Brunel
BHM Track day - Goodwood (May 2013)
LATEST PAINTING PHOTOS - CHUNKY 4/4'S RACING CAR
Vintage Stereo
by asbojohn
25/05/13 08:27 PM
Leather Blisters?
by dogmanjack
25/05/13 07:42 PM
No such thing as a simple job!
by Alan Patterson
25/05/13 05:02 PM
3 Wheeler seen at Montlhéry
by lotusien
25/05/13 03:14 PM
3 Wheeler enthusiast
by lotusien
25/05/13 02:55 PM
How to start the Third World War!
by GerryWal
25/05/13 02:26 PM
The Preacher
by Jack The Lad
25/05/13 09:11 AM
Peter R, willi, lotusien, fathergoose, HMSMotorsport
2873 Registered Users
2873 Members
51 Forums
11072 Topics
#101343 - 17/08/12 05:07 AM Level
constantin Offline
My 4X4 Sport 2010 has 14000 km and preview what I was lower than 2 cm s front left.
since the damping is mounded into any hole of the road
what should he do?
    change the main spring?
    shim to raise the car?
thank you for your advice
#101345 - 17/08/12 06:29 AM Re: Level [Re: constantin]
pandy Offline
Loc: West Paris, France
Fit a barrel of beer to the right rear.
Giles. 4/4 sport.
#101347 - 17/08/12 07:14 AM Re: Level [Re: pandy]
OZ 4/4 Offline
Loc: Sydney, Australia
Or a few cases of "Fat Bastard"
#101352 - 17/08/12 07:41 AM Re: Level [Re: pandy]
Wirewheel Offline
Loc: South Warwickshire
Welcome to the forum Constantin,
This subject has been discussed on here before however, apart from a tie down issue for vehicles transported to Australia, there was no definitive reason established for an apparent lean.
If you are lucky to have access to a level car lift you could take measurements
of the car from the chassis as a datum and take it from there.
I just wonder if it is the body that is not level, as it is put together by hand.
Just a thought.
#101354 - 17/08/12 08:14 AM Re: Level [Re: pandy]
Jack The Lad Offline
Is that full or empty .
#101389 - 17/08/12 01:52 PM Re: Level [Re: Jack The Lad]
vincentvg Offline
Loc: Devon, UK
According to my dealer - who had my car in for service last week, and checked the ride height - my chassis is level (more or less): the difference in measurement from the ground to rear wheelarch lip each side is due to "hand-built" tolerances.
Can't say I'm entirely convinced by this - but the difference is small enough after a continental trip two-up to be disregarded, I feel.
Now that we're back in Blighty, and the Roadster's carrying my not inconsiderable bulk solo, more often than not, doubtless it'll sag again drive
Nick
Connaught Green Roadster V6
#101391 - 17/08/12 02:05 PM Re: Level [Re: vincentvg]
Dean-Royal Online   happy
Loc: UK (up north)
Attending an Autotrade show Birmihgham back in the very early 90s i was showing interet in a new Jig that was Lazer and computer pointed. On the jig was sat a Rover 800 series 2.
The rear Chassis legs were out 12mm in Height, (this was an original car not a repaired one)
When i queried this, the Demonstrator replied Rover say this is an acceptable tolerance. mmmmmmmmmmmmmmmmmm hence i never owned a Rover.
33 MAX v SPIDERMAN
#101429 - 17/08/12 07:21 PM Re: Level [Re: constantin]
Frank 4x4 Offline
Green & Grown Up
Loc: Buckinghamshire UK.
Originally Posted By: constantin
My 4X4 Sport 2010 has 14000 km and preview what I was lower than 2 cm s front left.since the damping is mounded into any hole of the road what should he do? change the main spring? shim to raise the car? thank you for your advice
I can't offer any useful advice other than to measure the main springs on level ground and to check the tyre pressure are the same, but there may be something useful to help your thoughts here -
http://www.gomog.com/allmorgan/front.htm
Also From GoMog Troubleshooting
Ride and Handling Worn shock absorbers or other suspension components - or improper tire inflation - can contribute to poor cornering. While there is no hard and fast rule about when to replace shock absorbers or struts, try this test: bounce the vehicle up and down hard at each wheel and then let go. See how many times the vehicle bounces. Weak shocks will allow the vehicle to bounce twice or more. Springs do not normally wear out and do not need replacement unless one corner of the vehicle is lower than the others. Overloading your vehicle can damage the springs. Balance tires properly. An unbalanced or improperly balanced tire causes a vehicle to vibrate and may wear steering and suspension components prematurely.
or here thumbs -
https://sites.google.com/site/morganatica/
Edited by Frank 4x4 (17/08/12 07:26 PM)
#101499 - 18/08/12 06:06 PM Re: Level [Re: Dean-Royal]
Graham, G4FUJ Offline
Loc: Cheltenham, GLos. UK
That would not surprise me in the slightest!!
'01 Freelander TD4; '90 Defender 90 SW
