4 members (John V6, david nathan, Bitsobrits, linklaw), 304 guests, and 43 robots.
John V6 84
+8Rich 68
DaveW 67
9,203 Registered Users
Goggle eyed
by Roady - 19/07/25 06:16 PM
by t50 - 19/07/25 12:07 PM
Lions Tour
by OZ 4/4 - 19/07/25 11:55 AM
Morgan rebuild on Facebook
by TBM - 19/07/25 10:50 AM
by Nick B - 19/07/25 10:22 AM
Glitch
brake reaction stay fitting
by Caveman, July 15
BHM Breakfastclub 5/7/2025
by DirkM, July 13
Parrot upgrade
Parrot upgrade
by Mr Mogoo, June 19
Topics48,331
Posts812,868
Members9,203
kamo30
Folks,
Whilst 'surfing' for sage advise on possible power upgrades to the 'screaming' Zetec I came upon these words off the "t'internet". (escortevolution.co.uk)
The thread was titled - "Zetec Tuning Myths Busted".
It should be noted that they refer to Ford ECU's and not to be confused with Morgan ECU's.
I would add that I believe that the last two points discussing exhausts and 'aftermarket chips' do not refer to any of the well known Morgan after market suppliers and I certainly enjoy a much improved engine through the use of a 4-2-1 manifold and sports cat. Yet to sample a Chip Remap or other upgrades (apart from my improved air filter feed).
I pass no other comments but thought it might open up some discussion and possibly as the title suggests dispel any 'myths' (certainly helped me) although I still might try a larger throttle body thinking and maybe some cams spend and.....
Here goes......
"Upgrading to a 2L MAF sensor"
Myth: Fitting a MAF sensor from a 2L (2 litre) Mondeo will increase power on a 1.8 Zetec. Common assumption is it will let more air flow through.
Fact: The MAF is a sensor designed to measure airflow through the engine. It comprises of a metal body of a particular diameter with a calibrated sensor stuck in the side of this calibrated 'pipe'. The engine control unit (ECU) is specially calibrated to understand the output of the particular MAF sensor originally fitted to the car. Changing to a different MAF sensor with a different linearisation output will confuse the ECU, effectively incorrectly fuelling the engine.
Fact: Some 115ps and 136ps engines share the same MAF part code.
Fact: No additional airflow and potential for incorrect fuelling does not lead to an increase in power.
Status: TOTALLY BUSTED!!!
"Upgrading to 2L fuel injectors"
Myth: Fitting fuel injectors from a 2L Mondeo to a 1.8 Zetec will increase engine power.
Fact: The factory (Ford) ECU is specifically calibrated to the fuel injectors it comes with, with regards to how much they flow and how they respond. Changing to smaller or larger injectors will either lead to lean or rich conditions and transient fuel control will most likely be non-perfect, leading to increase fuel economy and a less pleasant drive
Fact: Fitting injectors that are too large has the potential to wipe out your engine due to bore wash conditions.
"Upgrading to 2L ECU"
Myth: Replacing the 1.8 ECU with one from a 2.0 will increase power.
Fact: The factory ECU is calibrated perfectly to work with the 1.8 engine. Changing the ECU will result in incorrect engine control, potentially fatal to the engine. The same applies to changing any sensors on the vehicle.
"Upgrading to a 2L Throttle Body"
Myth: Fitting a throttle body from a 2L Mondeo will increase throttle response and increase power output.
Fact: A larger throttle body will increase throttle response. The relevant definition of throttle response here is the speed at which you achieve peak airflow (and thus peak power) when you depress the throttle pedal.
Fact: The 115ps throttle body isn't what restricts the engine to this power. Fitting a larger throttle body won't increase airflow due to other restrictions on the intake tract so no additional power will be created.
Fact: Fitting the larger TB with no additional airflow will reduce throttle resolution. This means you'll reach your actual true full throttle (full power) with less throttle pedal being required than with the correct TB. This is where the common misconception comes from that it is more 'responsive'.
Status: MAINLY BUSTED!!!
"Upgrading to 2L Cams"
Myth: Fitting a pair of cams from the 2L Mondeo engine to a 1.8 Zetec will give you more power.
Fact: The increase in duration and lift of the 2L cams may increase engine output by a couple of horsepower at high rpm's.
Fact: Cams are no miracle. If you've done nothing to make the engine breathe better, by changing cam profile all you are doing is shifting the power band. This comes at a cost, and for the sake of a couple of peak horsepower which you'd never notice, you're going to lose torque in the low and mid-range of your power band which ultimately will make you slower.
Status: PARTIALLY BUSTED!!!
"Upgrading to a FSE Power Boost Valve"
Myth: Replacing the factory fuel pressure regulator with an aftermarket unit will increase engine response.
Fact: The factory ECU is calibrated to work at a certain fuel pressure and the transient fuel and spark controls that are very well calibrated are designed to work with the specific FPR that comes on the engine. Changing to a 'faster responding' fuel pressure regulator (effectively what an FSE PBV claims to do) will upset the fuelling of the car leading to a performance decrease and most likely unnecessarily-increased fuel consumption. The ECU knows how the factory FPR behaves and is calibrated to supply the correct amount of fuel under transient conditions (eg when you stamp on the throttle).
"Fitting an aftermarket chip"
Myth: Plugging in an aftermarket off-the-shelf chip/remap will increase engine power.
Fact: An aftermarket chip/remap typically alters the base fuel and spark tables that the ECU uses to control the engine. Most of these chips/remaps/modules either add fuel or advance the ignition timing of the engine. The factory calibration is already running excessively rich (to keep the catalytic converter at a relatively low temperature) so adding more fuel will gain no power (potentially a loss) and the spark angle is precisely mapped for peak torque/power so advancing will gain nothing.
Fact: A proper custom mapped chip for your particular car could gain a few horsepower, depending on modifications. An expensive option though, unless you consider say £100 per horsepower a fair price.
"Fitting an aftermarket exhaust manifold (4-2-1, 4-1)"
Myth: Replacing the factory exhaust manifold with an aftermarket tubular manifold will increase engine power.
Fact: Unless you have done drastic changes to the engine to make it flow more air, fitting a higher flower exhaust manifold will not increase engine power.
Fact: 99% of the off-the-shelf aftermarket manifolds are poorly designed and will most likely not perform as well as the OEM part.
Fact: A well designed exhaust manifold and system with the right engine modifications/spec will increase engine power.
Keith
Interesting post....food for thought.
Drive on the Wild Side
Interesting stuff, not too surprised, over recent years with injection systems, emission control, and trying improve efficiency, manufacturers have had to spend lots of time and money designing and tuning engines for max performance. Why anyone would anyone think that just swapping one part for a similar bigger one would make it give more power out, I don't understand.
Adrian
It's not by coincidence that these tuning product suppliers rairly have in house rolling roads, those that do are not that interested in an agreement where no payments are made unless the vehicle achieves their stated figures, they often state 'other factors' which is true but there is also much smoke and mirrors. Claims that bolting on a manifold or air filter will give XYZ BHP increase are often not realised.
BR Colin
I suspect that in many cases, a replacement "sports" air filter and sports exhaust make the car feel quicker due to the increased noise.
A good book to read is..
Modern Engine Tuning
By
A Graham Bell.
Haynes sell it.
He explores a whole range of factors and gives results of tests done to each change in the engines. Showing things like power changes over various rev ranges for the various trials.
It also has a section blowing away some myths/claims about gadjets and " snake oil remedies".
Quite an interesting book
It has a section on air filters that covers tests of various brands, also design mods to help air input, both more air and also air velocity.
Worth a read.
He confirms all of minikeefee's comments and shows actual test results.
Graham Bell's book is very good - also there are little gems out on the internet of web capable engineers (there do not seem to be that many who are open to sharing the detail)... but this library is a VERY good read for the armchair novice.
http://www.guy-croft.com/index.php?sid=d4960773cd7bf6d6716732050978ce8c
Talk about stripping back the BS! and turning the Graham Bell theories into case studies with pictures, scientific measurements etc.
Just remembered another book....
Engine Management
Dave Walker
Also Haynes.
Covers some good topics with lots of photos and " how to.." sections.
Covers both carb engines and efi types.
It came with a CD to load to a PC ...Emerald Enginge Management.
Allows some playing with mapping etc.
Dave Walker was an editor of Practical Mechanics years ago.
Now runs his garage doing mapping.
See him in Practical Performance Car magazine ....
Yes, I've got the Dave Walker book, it's a very good introduction.
