10 members (MJF, GrandadC, Oskar, B3MOG, JohnHarris, t50, +8Rich, DJC, High Hamster, david nathan),
312
Topics48,335
Posts812,889
Members9,203
Posts: 3,383 Likes: 12
Posts: 3,383 Likes: 12 |
There are actually two very similar but different thread forms, not interchangeable so make sure they match the brass fittings or run a small tap through. Can't quote the thread forms I just know they are different, I sourced some lamps from SVC in Tamworth and as mine had clear lenses and orange bulbs thought I would just swap the lenses onto the new bodies....not quite that simple, the lengths are also slightly different.
Posts: 2,392 Likes: 14
Posts: 2,392 Likes: 14 |
Ah! Two threads on the screws then not on the forum!
1969 4/4 1995 plus 8 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 14,976 Likes: 1
Posts: 14,976 Likes: 1 |
So it's not just MMC who mix things up
Richard 1976 4/4 4 Seater
Posts: 1,036 |
Colin is correct.
The brass inserts supplied with the clear lenses by SVC are metric, the original Lucas inserts are BA.
I had spare 'long' Lucas chrome BA screws and so ran a BA tap through the insert and used the better Lucas ones.
Posts: 5,653 Likes: 4
Posts: 5,653 Likes: 4 |
The clear lenses I purchased came with replacement threaded inserts.
Martin (Deano)
Posts: 1,036 |
For anyone mildly interested in the minutae of such matters.....
Cancel my previous comment about the original Lucas chrome screw being a BA thread, it is not.
The thread is UNC (course). I can't make out enough of the markings on the tap but it's UNC with a 2.8mm drill size.
What a sad life I lead!
Posts: 11,854 Likes: 137
Posts: 11,854 Likes: 137 |
What a sad life I lead! You have checked, and I haven't, so you must be right, but I'm very surprised. 5BA is 2.7mm / 43tpi, Number 6 UNC is 2.8mm / 32 tpi, 3.5mm metric is 2.9mm / 42.3 tpi (.6mm pitch) Quite a difference in pitch?
Posts: 1,036 |
Ah someone at least as sad as me!!
Thank you Tim, you have clarified the markings on my tap. Big No 6 with a 32 in smaller letters; big and small are relative of course because the tap is rather small and a large magnifying glass is demanded to see the markings!
Thank you Tim, you have clarified the markings on my tap. Big No 6 with a 32 in smaller letters; big and small are relative of course because the tap is rather small and a large magnifying glass is demanded to see the markings! Personally, I don't think we're sad at all, David! I have quite a large stock of M3.5mm stainless capscrews, so I retap to that size when I get a screw that's a bit chewed up.
Posts: 1,036 |
Personally, I don't think we're sad at all, David! I'm in complete agreement with you Tim. But then I am slightly biased!
