Glitch
Topics48,324
Posts812,827
Members9,202
Posts: 26,746 Likes: 419
Posts: 26,746 Likes: 419 |
As we plan our move I am thinking of the essentials. One of which is a shed.
I see that now you can get plastic interlocking shed bases kits rather than laying cement. Has anyone done? If yes what was good , what was bad?
Posts: 611 |
Yes, I did this with my wooden garage base. Good thing, the tiles are recycled plastic and fit together easily. Also provides insulation from ground. Bad thing getting it level unless you can easily level your site. Concrete is more expensive but will find its own level when poured. The kit I bought came with a membrane so it will breathe whereas concrete never will and can cause condensation when cold.
Morgan 4/4 Sport Competition
Posts: 11,852 Likes: 137
Posts: 11,852 Likes: 137 |
I used them when I moved our aluminium greenhouse. I dug out a flat area, put down a layer of pea gravel, then the interlocking plastic tile jobbies, then I filled the pockets with more pea gravel.
I was quite happy with the result for a greenhouse, I think if I was doing it for a shed I'd consider using paving slabs over gravel to provide a more stable surface. Getting them truly level took quite some time - but then I was working on a slope so digging a flat area wasn't completely trivial.
Posts: 28,413 Likes: 177
Posts: 28,413 Likes: 177 |
My shed is on paving slabs over gravel. Laid by younger stepson - one of his trades, groundwork.
Sold L44FOR 4/4 Giallo Fly '09 Gen2 MINI Cooper ragtop '90 LR 90 SW
One good thing for Suffolk it will be flatter than the Chilterns! Thanks guys.
Posts: 1,615 Likes: 1
Posts: 1,615 Likes: 1 |
I have just laid such a base for a 10x8ft shed. I got the plastice sections from a company on the web called "the shed base company". Very quick delivery and much less hastle than concrete. My site was not level so I dug it out, levelled with ballast that I happened to have and bordered the site with gravel boards. Filled with pea grit the whole base seems stable.
John 1992 plus4 connaught green
Posts: 5,587 |
https://www.sheds.co.uk/blog/are-plastic-shed-bases-any-good/Maybe I should have done this a few days ago ! Shed going up tomorrow !
Posts: 1,576 Likes: 103
Posts: 1,576 Likes: 103 |
One of my sheds has both a 4/4 and a Plus 4 chassis cast in the them as re-enforcement, cheaper than rebar!
Arwyn
Posts: 764 Likes: 8
Posts: 764 Likes: 8 |
Arwyn You should have learnt the first time not to drive on wet concrete...
1993 T16 +4 Lancia Blue.
Posts: 9,285 Likes: 69
Posts: 9,285 Likes: 69 |
Good timing for this post. I am starting to plan the garden in the new house.  has mentioned putting a shed up. That could mean her design/use not mine  I will have to tread carefully. I have plenty of spare slabs so that will be my probable method.
