7 members (Tweed19er, Methodical Ninja, Alanv60, Image, Joe Speetjens, JohnHarris, vbalddave), 292 guests, and 29 robots.
John V6 83
+8Rich 69
DaveW 67
Luddite 57
9,203 Registered Users
by Oskar - 20/07/25 04:13 PM
Goggle eyed
by Roady - 19/07/25 06:16 PM
by t50 - 19/07/25 12:07 PM
Lions Tour
by OZ 4/4 - 19/07/25 11:55 AM
Morgan rebuild on Facebook
by TBM - 19/07/25 10:50 AM
by Nick B - 19/07/25 10:22 AM
Topics48,335
Posts812,890
Members9,203
kamo30
#505648 27/03/18 04:04 PM
John V6 Offline OP
As we plan our move I am thinking of the essentials. One of which is a shed.
I see that now you can get plastic interlocking shed bases kits rather than laying cement.
Has anyone done? If yes what was good , what was bad?
2025 MG ZS EV aka Trigger
John V6 #505655 27/03/18 04:36 PM
Yes, I did this with my wooden garage base. Good thing, the tiles are recycled plastic and fit together easily. Also provides insulation from ground. Bad thing getting it level unless you can easily level your site. Concrete is more expensive but will find its own level when poured.
The kit I bought came with a membrane so it will breathe whereas concrete never will and can cause condensation when cold.
Morgan 4/4 Sport Competition
John V6 #505656 27/03/18 04:37 PM
I used them when I moved our aluminium greenhouse. I dug out a flat area, put down a layer of pea gravel, then the interlocking plastic tile jobbies, then I filled the pockets with more pea gravel.
I was quite happy with the result for a greenhouse, I think if I was doing it for a shed I'd consider using paving slabs over gravel to provide a more stable surface. Getting them truly level took quite some time - but then I was working on a slope so digging a flat area wasn't completely trivial.
John V6 #505658 27/03/18 04:52 PM
My shed is on paving slabs over gravel.
Laid by younger stepson - one of his trades, groundwork.
'09 Gen2 MINI Cooper ragtop
John V6 #505671 27/03/18 05:35 PM
John V6 Offline OP
One good thing for Suffolk it will be flatter than the Chilterns!
Thanks guys.
John V6 #505679 27/03/18 05:47 PM
I have just laid such a base for a 10x8ft shed. I got the plastice sections from a company on the web called "the shed base company". Very quick delivery and much less hastle than concrete. My site was not level so I dug it out, levelled with ballast that I happened to have and bordered the site with gravel boards. Filled with pea grit the whole base seems stable.
1992 plus4 connaught green
John V6 #505683 27/03/18 05:53 PM
https://www.sheds.co.uk/blog/are-plastic-shed-bases-any-good/
Maybe I should have done this a few days ago ! Shed going up tomorrow !
John V6 #505687 27/03/18 06:19 PM
One of my sheds has both a 4/4 and a Plus 4 chassis cast in the them as re-enforcement, cheaper than rebar!
Arwyn
jbk Offline
Arwyn
You should have learnt the first time not to drive on wet concrete...
1993 T16 +4 Lancia Blue.
John V6 #505722 27/03/18 07:57 PM
Good timing for this post. I am starting to plan the garden in the new house. swmbo has mentioned putting a shed up. That could mean her design/use not mine innocent
I will have to tread carefully. I have plenty of spare slabs so that will be my probable method.
