4 members (GrumpyPa, Adam12, DJC, Jo S), 304 guests, and 41 robots.
John V6 85
+8Rich 68
DaveW 67
9,202 Registered Users
Goggle eyed
by Roady - 19/07/25 06:16 PM
by t50 - 19/07/25 12:07 PM
Lions Tour
by OZ 4/4 - 19/07/25 11:55 AM
Morgan rebuild on Facebook
by TBM - 19/07/25 10:50 AM
by Nick B - 19/07/25 10:22 AM
Glitch
brake reaction stay fitting
by Caveman, July 15
BHM Breakfastclub 5/7/2025
by DirkM, July 13
Parrot upgrade
Parrot upgrade
by Mr Mogoo, June 19
Topics48,329
Posts812,862
Members9,202
#524843 30/07/18 09:21 AM
Clipper Offline OP
Can anyone advise 2010 Plus 4 front brake pads part details and where to order from so my local garage can fit them?
The garage is struggling to source them but can fit them.
MMC dealer too far away to fit, but would I need to order the pads from them?
2016 Carmine Red 991.2 C4S
2025 MG ZS EV aka Trigger
Austin Princess..... innocent
My Plus 4 is currently "in dock" receiving a total brake overhaul.
It needed two front discs with pads plus new rear wheel cylinders.
The parks were ordered from Krazy Horse so they may be able to assist.
Reg
Mintex mlb52 on eBay at less than £20 per set for standard compound. Or look at EBC site and enter your Reg number and they’ll offer a selection of compounds from standard, green, yellow and red.
Note, if they are CAPARO calipers, you may need replacement w-clips as they often disintegrate when pressed to get retaining pins out. Available from Rimmers at about £1 each. (As Dave said, Austin Princess ones!)
Note, when fitting, the pads may be a little bigger than the disc on the outside so a light chamfering on the edge of the pad may be desirable to save a shoulder building up in the future. (Not because of duff pads.This problem was there from design stage when new)
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Clipper Offline OP
Ordered from EBC - Believe they are CAPARO but it says caliper is Lockheed on EBC website - hope that wont be a problem.
Failed to locate W clips.
I have just looked on the Rimmer site, searched for “brake pad clips” and they are the first item to be shown. Part number QP2740 @£1 +vat each. P&p is about £3. I know they fit as I have used them on CAPARO callipers.
The Lockheed calipers take similar pads but the retaining pins are different. You wouldnt need the W clips for those.
Read all about it in Dave’s book?
Doug
1958 Triton 650
Dave who?
The mayor of Mexborough I believe !!!!
