9 members (jim109b, BLUE+4, Jeffpee, Paul F, RibbleAdventures, Ruut Bianchi, teknome, Bishmog, dogmog),
556
43
Glitch
Topics48,331
Posts812,877
Members9,203
Posts: 4,491 Likes: 65
Posts: 4,491 Likes: 65 |
Can anyone advise 2010 Plus 4 front brake pads part details and where to order from so my local garage can fit them?
The garage is struggling to source them but can fit them.
MMC dealer too far away to fit, but would I need to order the pads from them?
2021 Lapis Blue Plus 6  You know it makes sense!  2016 Carmine Red 991.2 C4S
Posts: 26,746 Likes: 419
Posts: 26,746 Likes: 419 |
Posts: 21,865 Likes: 167
Posts: 21,865 Likes: 167 |
Austin Princess.....
Posts: 5,366 Likes: 14
Posts: 5,366 Likes: 14 |
My Plus 4 is currently "in dock" receiving a total brake overhaul. It needed two front discs with pads plus new rear wheel cylinders. The parks were ordered from Krazy Horse so they may be able to assist.
Posts: 1,950 Likes: 40
Posts: 1,950 Likes: 40 |
Mintex mlb52 on eBay at less than £20 per set for standard compound. Or look at EBC site and enter your Reg number and they’ll offer a selection of compounds from standard, green, yellow and red. Note, if they are CAPARO calipers, you may need replacement w-clips as they often disintegrate when pressed to get retaining pins out. Available from Rimmers at about £1 each. (As Dave said, Austin Princess ones!) Note, when fitting, the pads may be a little bigger than the disc on the outside so a light chamfering on the edge of the pad may be desirable to save a shoulder building up in the future. (Not because of duff pads.This problem was there from design stage when new)
Ordered from EBC - Believe they are CAPARO but it says caliper is Lockheed on EBC website - hope that wont be a problem.
Failed to locate W clips.
Failed to locate W clips. I have just looked on the Rimmer site, searched for “brake pad clips” and they are the first item to be shown. Part number QP2740 @£1 +vat each. P&p is about £3. I know they fit as I have used them on CAPARO callipers. The Lockheed calipers take similar pads but the retaining pins are different. You wouldnt need the W clips for those. Read all about it in Dave’s book?
Posts: 2,308 |
Posts: 2,308 |
The mayor of Mexborough I believe !!!!
