7 members (Tweed19er, david nathan, Adam12, Graham, G4FUJ, MDS61, James B W, t50),
322
Glitch
Topics48,329
Posts812,862
Members9,202
Posts: 979 |
One of my sun visors on Aero8 S3 now hangs limply (no personal comments please) and the other flops down after big bumps. The two rods within the tube should be a tight friction fit and in order to fill the gap I have tried duct tape, brown vinyl tape, aluminium foil and packing the centre space tight with sponge rubber. Obviously nothing has worked.  Is there a DIY fix or is it simpler to just post them back to Malvern for them to fix? Thanks in anticipation
Posts: 3,422 Likes: 5
Goodwood Drifter Talk Morgan Addict
Posts: 3,422 Likes: 5 |
proposable answers: DaveW: neoprene around the tube 1560: take them off, weight high off the center of the car Boshly: look in the USA, they got BIG and sturdy visors Simon: factory after-sales-service, only them can make you something stylish Aeroman: I'm not in the country Philippo: you're car isn't yellow???? Paul Hurst: I can play some music, if 1560 sings it makes the sun go away Ivo: @Philippo: you forgot black!!!! 109er: Porsche R&D are fixing mine Heinz: sorry, analysing the road-behavior of my Roadster on a wet N'Ring
Last edited by 1560; 01/02/11 09:31 AM. Reason: got feaver attack due to overstressing my body on the mountain-bike
Posts: 453 |
an other possible answer:
Alway drive the sun in your 6 o'clock.
H3
Alway drive the sun in your 6 o'clock. only hard when you drive arround your little island  (or already back in EU???)
Steven sold: M3W, Aeromax,V6, 4/4 4seater now: +fourLM62
Posts: 21,865 Likes: 167
Posts: 21,865 Likes: 167 |
If the rod & tube are both metal, tinning a layer of solder on the rod would work, but is labour intensive. A slight bend in the rod might be enough to do it, or a few strikes with a chisel on an anvil. I suspect the factory might chose the latter as a quick fix. Mole grips might persuade the tube into a less than round shape, but protect the visor with a neoprene shield at the very least. If the rod is soft metal, molegrips might just squeeze it out of round enough to grip.
Posts: 3,827 Likes: 4
le Asbo du Bling Talk Morgan Addict
Posts: 3,827 Likes: 4 |
If you find a solution please let me know one of mine is doing the same. Not that its seen much sun lately
Slowly going green
Posts: 7,363 |
proposable answers: DaveW: neoprene around the tube 1560: take them off, weight high off the center of the car Boshly: look in the USA, they got BIG and sturdy visors Simon: factory after-sales-service, only them can make you something stylish Aeroman: I'm not in the country Philippo: you're car isn't yellow???? Paul Hurst: I can play some music, if 1560 sings it makes the sun go away Ivo: @Philippo: you forgot black!!!! 109er: Porsche R&D are fixing mine Heinz: sorry, analysing the road-behavior of my Roadster on a wet N'Ring Excellent 1560
Brian
1970 Morgan Plus 8 - Moss Box (Indigo Blue) 2014 Morgan SP1 (Rocket Red) 2015 Morgan Plus 8 (Rocket Blue)
Posts: 7,820 Likes: 81
Posts: 7,820 Likes: 81 |
proposable answers: DaveW: neoprene around the tube 1560: take them off, weight high off the center of the car Boshly: look in the USA, they got BIG and sturdy visors Simon: factory after-sales-service, only them can make you something stylish Aeroman: I'm not in the country Philippo: you're car isn't yellow???? Paul Hurst: I can play some music, if 1560 sings it makes the sun go away Ivo: @Philippo: you forgot black!!!! 109er: Porsche R&D are fixing mine Heinz: sorry, analysing the road-behavior of my Roadster on a wet N'Ring Excellent 1560 Brilliant but he missed AsboJohn: paint your car pink and no one will notice the flappy sun visor.
On a serious note - is it worth trying to put another stitch at the bar end? This would increase the tension between the leather sun visor and the metal bar.
Posts: 979 |
On a serious note - is it worth trying to put another stitch at the bar end? The leather does not come into contact with the two bars that are screwed to the w/screen frame. The two bars and the tube they go into, and to which the leather is attached by glue, appear to be stainless steel and probably beyond the power of mole grips. I am tempted with bashing the tube  (with the bars in place) to create some pressure points but not if this does not work and makes them irreparable by the factory - although maybe just a new frame is the answer. Mine are so bad that if you hold the visor vertically, the bars just drop out!  Tinning with solder might work, I'll have to find summat to practice on.......
