1 members (CooperMan),
539
Topics48,335
Posts812,896
Members9,203
Posts: 7,916 Likes: 216
Posts: 7,916 Likes: 216 |
See my post above Nick. The grease gun head needs to lock onto the nipple. If it doesn't it needs adjusting or you need a new head.
My new Wanner grease gun had this issue. Since changing the head no issues. Once locked on grease can be squirted in at almost any angle without it leaking out of the sides. Sometimes a little difficult to break head off nipple after greasing, but moving it beyond normal limit will work.
Posts: 510 Likes: 1
Posts: 510 Likes: 1 |
I’d say the gun end is too big and not going all the way on. Unscrew the nipple a bit and try again. Don’t forget to do it back up again.
Simon 2002 4/4 1936 Austin 12 light 4 Ascot saloon 2023 AMG Mercedes C300e estate 2021 Audi A1 sport
Posts: 2,272 Likes: 7
Posts: 2,272 Likes: 7 |
A flexible hose between the head and body of the gun helps a lot at times like these. Since doing this I have cut down the number of issues a lot.
Also try to slide the head on from the side rather than a full frontal attack, this will help preserve its 3 "claws" which latch onto the nipple.
Posts: 5,107 Likes: 56
Black Rat Charter Member
Posts: 5,107 Likes: 56 |
I've always had a problem clamping on to nipples
Posts: 625 |
A flexible hose and one of these makes it a breeze http://www.alemlube.com.au/wp-content/up...ion%20Sheet.pdf Plenty of other brands of this type of coupler too now
Cheers John 2011 4/4 - "Elrond" 2007 Elfin C3 Clubman - “Gimli”
Posts: 5,217 Likes: 121
Posts: 5,217 Likes: 121 |
I bought one of these and found it to be totally useless. The coupler supplied with my grease gun is far more effective once installed on a flexible pipe.
Posts: 2,040 Likes: 71
Posts: 2,040 Likes: 71 |
I just ask the actress to turn to the other side!!
Bruce 1964 4/4 Series V Comp (Megan) 1994 +8 (Maurice) 2013 M3W (Olga)
Posts: 465 |
I've always had a problem clamping on to nipples I wondered when someone would latch on to this!
Dark Red 4/4 80th Anniversary
Posts: 5,181 Likes: 2
Posts: 5,181 Likes: 2 |
I just ask the actress to turn to the other side!! . Are you a bishop ?
