3 members (Malcolm T, Fjemog, Image), 328 guests, and 40 robots.
John V6 85
+8Rich 68
DaveW 67
9,202 Registered Users
Goggle eyed
by Roady - 19/07/25 06:16 PM
by t50 - 19/07/25 12:07 PM
Lions Tour
by OZ 4/4 - 19/07/25 11:55 AM
Morgan rebuild on Facebook
by TBM - 19/07/25 10:50 AM
by Nick B - 19/07/25 10:22 AM
Glitch
brake reaction stay fitting
by Caveman, July 15
BHM Breakfastclub 5/7/2025
by DirkM, July 13
Parrot upgrade
Parrot upgrade
by Mr Mogoo, June 19
Topics48,329
Posts812,860
Members9,202
John,
Librands supplied me a spacer to go between the rack and spare wheel of my Plus Four - the spacer might do the job for you too!
Robbie
2021 Plus Four -- Helga
211-WX-1433
Or fit one of those umbrella storage tubes. Uncle Melvyn sells them.
Nick
RJW #720526 05/10/21 06:21 PM
Originally Posted by RJW
How about leaving them and placing a stainless steel rod or pipe running from side to side between the brackets?
That's what I did, as I'm not keen on the rear end look with the rack on, but the brackets are a bit of a pain to remove
I used a piece of 16mm solid SS bar, drilled & tapped each end, so you just put a bolt in to hold it in the bracket, looks quite neat
John V6 Offline OP
Bit beyond my skill set or tools Jon but I might get some tube and threaded bar to do the same
2025 MG ZS EV aka Trigger
Well you did a great job of the polishing thumbs
However, I can't think how to carry the sidescreens without the rack.
One of the many benefits of the Sport model Ivor.
Just a thought...Not sure how this panel gets fixed to the car body, but if it is to be regularly removed, hopefully some thought has gone into how to prevent rub marks appearing on the body, as mating surfaces may well flex a bit with general vibration and bumpy roads. Does it come with a circular gasket?
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
I am still wondering about what to do with the arms of the rack that bolt to the chassis. To remove & have a gap in the rear valance or to keep them on.
The idea will be to have the ability to add back the spare & rack for longer tours.
I'd be tempted to remove them John if I didn't plan the need for some time.
That's the advantage of having overriders. The rear carrier for that variant just slots onto the vertical pins of brackets secured to overrider mounts and essentially hidden, allowing speedy removal/replacement of carrier.
Could you get overriders on the brackets?
1994 +8, BMW Calypso Red.
How do you open the boot?
John V6 Offline OP
I have added a neoprene foam round seal & will use washers to lift the panel off the rear where it screws on.
Over riders might have to wait for a big birthday
