3 members (DavidR, Jesper, BGW),
117
41
Glitch
Topics48,331
Posts812,880
Members9,203
Posts: 3,424 Likes: 26
Posts: 3,424 Likes: 26 |
John, Librands supplied me a spacer to go between the rack and spare wheel of my Plus Four - the spacer might do the job for you too!
Posts: 3,665 Likes: 43
Posts: 3,665 Likes: 43 |
Or fit one of those umbrella storage tubes. Uncle Melvyn sells them. Nick
Posts: 7,891 Likes: 241
Posts: 7,891 Likes: 241 |
How about leaving them and placing a stainless steel rod or pipe running from side to side between the brackets? That's what I did, as I'm not keen on the rear end look with the rack on, but the brackets are a bit of a pain to remove I used a piece of 16mm solid SS bar, drilled & tapped each end, so you just put a bolt in to hold it in the bracket, looks quite neat
Posts: 26,746 Likes: 419
Posts: 26,746 Likes: 419 |
Bit beyond my skill set or tools Jon but I might get some tube and threaded bar to do the same
Bit beyond my skill set or tools Jon but I might get some tube and threaded bar to do the same Well you did a great job of the polishing
Posts: 2,255 Likes: 2
Posts: 2,255 Likes: 2 |
However, I can't think how to carry the sidescreens without the rack. One of the many benefits of the Sport model Ivor.
Posts: 1,950 Likes: 40
Posts: 1,950 Likes: 40 |
Just a thought...Not sure how this panel gets fixed to the car body, but if it is to be regularly removed, hopefully some thought has gone into how to prevent rub marks appearing on the body, as mating surfaces may well flex a bit with general vibration and bumpy roads. Does it come with a circular gasket?
Posts: 7,916 Likes: 216
Posts: 7,916 Likes: 216 |
I am still wondering about what to do with the arms of the rack that bolt to the chassis. To remove & have a gap in the rear valance or to keep them on.
The idea will be to have the ability to add back the spare & rack for longer tours. I'd be tempted to remove them John if I didn't plan the need for some time. That's the advantage of having overriders. The rear carrier for that variant just slots onto the vertical pins of brackets secured to overrider mounts and essentially hidden, allowing speedy removal/replacement of carrier. ![[Linked Image]](https://i.imgur.com/YPalPvV.jpg)
Posts: 296 Likes: 4
Posts: 296 Likes: 4 |
Could you get overriders on the brackets?
1994 +8, BMW Calypso Red. 2002 4/4, 4 seater, BMW Calypso Red. How do you open the boot?
Just a thought...Not sure how this panel gets fixed to the car body, but if it is to be regularly removed, hopefully some thought has gone into how to prevent rub marks appearing on the body, as mating surfaces may well flex a bit with general vibration and bumpy roads. Does it come with a circular gasket? I have added a neoprene foam round seal & will use washers to lift the panel off the rear where it screws on. Over riders might have to wait for a big birthday
