9 members (meabh, mph, sewin, Craig Jezz, Saxonian, DaveW, Arwyn Williams, Alan Patterson, howard), 317 guests, and 44 robots.
John V6 83
+8Rich 68
DaveW 67
Luddite 58
9,203 Registered Users
Goggle eyed
by Roady - 19/07/25 06:16 PM
by t50 - 19/07/25 12:07 PM
Lions Tour
by OZ 4/4 - 19/07/25 11:55 AM
Morgan rebuild on Facebook
by TBM - 19/07/25 10:50 AM
by Nick B - 19/07/25 10:22 AM
Glitch
brake reaction stay fitting
by Caveman, July 15
BHM Breakfastclub 5/7/2025
by DirkM, July 13
Parrot upgrade
Parrot upgrade
by Mr Mogoo, June 19
Topics48,331
Posts812,877
Members9,203
kamo30
Originally Posted by Jack & Jill 602
On our 1985 4/4 the ammeter is wired through an additional "starter relay" not shown on your diagrams.
The wiring diagram in our car's handbook also shows this relay.
Might this help explain what is going on?
Surely wasn't your car originally fitted with a voltmeter ? not an ammeter.
Owen
"bilibib"
1982 4/4 Twin Cam, Royal Ivory
1932 Super Sports, Duo tone(two tone)Green
It seems the early Lucas 11ac alternator with its complicated external voltage regulation was fitted to Morgan's until at least 1984 according to various wiring diagrams. These models seemed to continue using ammeters although Land Rover (from which we can often draw parallels) when they offered this alternator switched to voltmeters in the late 60's as shown above.
I think Jack's assumption the ammeter is wired "through" the starter relay is a red herring. The battery side ammeter terminal (brown wires) is just used as convenient connection point for main power to relay which then triggers starter solenoid. No current flows through ammeter when starter is operated therefore.
Pretty sure my '76 did not have an external voltage regulator. Of course, as I was not the first or even 4th owner, a newer alternator may well have been fitted smile
'09 Gen2 MINI Cooper ragtop
My '75 doesn't have a separate regie .... same proviso though .... it's been about a while and may have been modded.
TBM Offline OP
The more I think about it, I might just bypass the ammeter and connect the lead direct to the battery post on the solenoid. Will get maximum charge to the battery,and not risk any thermal issues with the ammeter wiring.
Makes sense electrically thumbs
The issue surrounding the wiring diagrams is that Morgan used the same wiring diagrams for a Plus 8 (which had an externally regulated alternator) and the 4/4 (which didn't)!
The Ford crossflow never used an externally regulated alternator.
Makes sense wiring it to the battery post on the solenoid.
On the crossflow rally cars we used a compact alternator from a Kubota, very light and powerful (60A to 95A) and cheap too - about 75 quid from the local Kubota dealers.
Arwyn
TBM Offline OP
Thanks for all the help.
All wired up using flexi 16mm2 110AMP cable direct to solenoid. While I was fiddling I also finally got round to fitting a strip fuse on the main brown cable (as recommended!).
Although not properly connected, there appears to still be conectivity between the two posts on the ammeter so will leave 'as is' for the time being. If any problems,I'll piggy back both wires on the same post. I've capped off the old alternator wire but left it, in case I ever want to revert back.
Sorry to do this thread to death but just been given this link.
It contains this very clear pictorial diagram of a 1972 4/4 11AC alternator and ignition wiring.
TBM Offline OP
In true Morgan style, mine is1972 but had an ACR alternator - only two wire and no Warning light relay/ Alternator Relay or Alternator Regulator. smile
The wiring diagram in my first post was for a 1973 4/4 and apart from the errant Brown wire is correct for mne. Mine is registed Dec 72 so they may have changed from AC to ACR towards the end of 1972,
