6 members (John07, MATTMOG, GrandadC, High Hamster, JohnHarris, AlyMatt), 305 guests, and 41 robots.
John V6 83
+8Rich 69
DaveW 67
9,203 Registered Users
by Oskar - 20/07/25 04:13 PM
Goggle eyed
by Roady - 19/07/25 06:16 PM
by t50 - 19/07/25 12:07 PM
Lions Tour
by OZ 4/4 - 19/07/25 11:55 AM
Morgan rebuild on Facebook
by TBM - 19/07/25 10:50 AM
by Nick B - 19/07/25 10:22 AM
Topics48,335
Posts812,889
Members9,203
kamo30
flaagan Offline OP
Curious if anyone's done an automatic transmission swap on a 60's-era +4? Looking to blow the dust off one of our two +4 projects (the '61), and a combination of factors have made the idea of converting it to an automatic a tempting thing to consider.
The car as-is doesn't have an engine or transmission, would likely source the engine from a TR3 block we have sitting around, or possibly the engine from the '66 as that vehicle's got other drivetrain plans. Goal would be a setup that would allow it to keep up with modern freeway speeds.
The size of the bellhousing required for a torque converter might be an issue that requires transmission tunnel mods that impacts footwell and pedal space. There are a couple of 5-speed options that have a history of success. I have one in my '67 +4 that makes freeway speeds much more comfortable. I don't think the tunnel had to be modified at all. One of those conversions might save you some expensive lessons about unintended consequences.
flaagan Offline OP
What conversion did you end up doing?
Standard Vanguard had auto transmission an an option, same block as a TR / +4 but rare as hen's teeth I would imagine.
1969 4/4
1995 plus 8
2002 Aero S1
2013 M3W
2014 Plus 8
Flaagan,
Morgan Spares has a conversion kit that uses the Ford T-9 box. That's what's in my car. Reportedly, it's the conversion that requires the least amount of modification. There is a direct link to the install guide on their website, but it appears to be broken. I was able to find the link here. I suggest you give Morgan Spares a call to discuss. I don't know the current situation with availability and pricing, but I'm sure they will let you know.
flaagan Offline OP
Flaagan,
Thanks, looking into that as a possibility.
