9 members (meabh, mph, sewin, Craig Jezz, Saxonian, DaveW, Arwyn Williams, Alan Patterson, howard),
317
44
Glitch
Topics48,331
Posts812,877
Members9,203
Posts: 84 Likes: 2
Posts: 84 Likes: 2 |
Hi All,
Anyone know what the 'real' torque setting is for the single wheel retaining nut is for spoked wheels?
The handbook is somewhat vague with the instruction 'hammer tight'! How very 'Morgan'!
Andy 2022 Plus Four / San Marino Blue
Posts: 2,062 Likes: 57
Posts: 2,062 Likes: 57 |
Hello Andy perhaps this link helps. This factory makes som of the Morgan whire wheels. Torque for wire wheelsRegards von Germany Bernt
Posts: 84 Likes: 2
Hi Bernt,
Thank you for that. 102Nm sounds about right. I was going to call the technical people at customer services at the factory but knew common sense would prevail on this forum!
Kind regards,
Andy
Posts: 150 |
That link is for conventional wheel bolts
Posts: 26,746 Likes: 419
Posts: 26,746 Likes: 419 |
For my S1 Roadster it was 80Nm. I checked with MMC . This is for alloys not for wire wheels.
Posts: 150 |
I have assumed that the original poster is talking about knock on centrelock wire wheels? If so 80Nm would probably result in them falling off
Sorry! Here the link for Knock-on centre caps - not the torque Info you want Fitting wire wheels
Oh sorry. I don't think folk used torque spanners on wires. Please ignore the 80Nm. For wires they need to be tight.
Posts: 42 Likes: 5
Posts: 42 Likes: 5 |
This is new to me too, my car is getting wire wheels too... Wire wheels this link works Go down to the bottom of the page, it says "don't overtighten them" and "As long as the hubs are fitted correctly then the spinners will self-tighten and lock as the car is driving"
Morgan Plus Four Metallic Emerald Green and Pebble Biscuit, 'clutchless'
Posts: 5,216 Likes: 121
Posts: 5,216 Likes: 121 |
The page linked to has the following line: There are no recommended torque settings for spinners and the exact number of turns will vary from one vehicle to the next.
I have always relied on a couple of knocks with the supplied hammer or a light tweak with the breaker bar I use for removal. They do self tighten in use - to the extent that mine can be tricky to remove as my painted wire wheels “grab” the nuts. As the text on the MWS site says: It is very important not to over-tighten as the threads are easily damaged.
