1 members (BertR),
288
Glitch
Topics48,331
Posts812,867
Members9,203
Posts: 18 |
Hi Gerhard, sorry to hear about your problem. I also have a M16 +4 and no local workshops here in Australia. My car is back on the road again after many months. My problem was mostly a non starting issue and so replaced most of the sensors and ECU with no difference. Eventually when ordering another part, I also bought a new distributor cap, rotor arm and spark plug leads. When I put these on, the car has started and run again; as I put them on at the same time, I don't know which one was the problem but think possibly the distributor cap?? Of course, your car may be a totally different issue. Maybe also check the vacuum hoses around the plenum chamber, throttle body flange & air line to the ignition ECU in case of leaks. There are some very good articles on the Gomog website and I have found a lot of the references to the Rover v8 are relevant to the M16 motor also. (some sensors are the same, also fuel pressure regulator) I can send you some links to articles I found helpful if you want to send me your email. Hope you can sort it out soon. Regards, Col
Posts: 26,746 Likes: 419
Posts: 26,746 Likes: 419 |
+1 for checking for air leaks. The ECU will be affected by that. I the Haynes manual on the Rover 820 may help you . This is the fault finding guide Engine stalls m Engine management system fault (Chapters 1 and 4). m Vacuum leak at the inlet manifold or associated hoses (Chapters 1, 2 and 4). m Fuel filter choked (Chapter 1). m Fuel pump faulty or delivery pressure low (Chapter 4). m Fuel tank vent blocked or fuel pipes restricted (Chapter 4). Engine lacks power m Incorrect ignition timing (Chapter 5). m Engine management system fault (Chapters 1 and 4). m Timing belt incorrectly fitted or incorrectly tensioned (Chapter 2, Part A or B). m Fuel filter choked (Chapter 1). m Fuel pump faulty or delivery pressure low (Chapter 4). m Uneven or low cylinder compressions (Chapter 2, Part A, B or C). m Worn, faulty or incorrectly-gapped spark plugs (Chapter 1). m Vacuum leak at the inlet manifold or associated hoses (Chapters 1, 2 and 4). m Brakes binding (Chapters 1 and 9). m Clutch slipping (Chapter 6). m Automatic transmission fluid level incorrect (Chapter 1)
How old are the HT leads? The insulation could be breaking down as the car gets hot.
Posts: 5,107 Likes: 56
Black Rat Charter Member
Posts: 5,107 Likes: 56 |
My first thought Keith until I read the end of his first post. Oops I missed that
Posts: 337 |
Hi there I would go straight to the Rotor arm in the distributor. There is a resistor or similar in the top that is known to cause this problem. I have experience of this, get a new rotor arm Ian.
Ian Morgan Family 1929 ( KTW 1100cc ) Morgan S/S 1934 Morgan F4 M3W 2012 Morgan +4 T 1991
Posts: 1,075 Likes: 1
Posts: 1,075 Likes: 1 |
Water in the petrol tank from E10 petrol?
Posts: 7 |
Thanks for your tips, I'll work them off as far as possible. Greeting Gerhard
