8 members (sewin, Saxonian, Craig Jezz, meabh, DaveW, Arwyn Williams, Alan Patterson, howard), 333 guests, and 43 robots.
John V6 83
+8Rich 68
DaveW 67
Luddite 58
9,203 Registered Users
Goggle eyed
by Roady - 19/07/25 06:16 PM
by t50 - 19/07/25 12:07 PM
Lions Tour
by OZ 4/4 - 19/07/25 11:55 AM
Morgan rebuild on Facebook
by TBM - 19/07/25 10:50 AM
by Nick B - 19/07/25 10:22 AM
Glitch
brake reaction stay fitting
by Caveman, July 15
BHM Breakfastclub 5/7/2025
by DirkM, July 13
Parrot upgrade
Parrot upgrade
by Mr Mogoo, June 19
Topics48,331
Posts812,877
Members9,203
kamo30
Sensei Offline OP
Hi guys, we are to remove front and rear wings on our 1973 +8, as they need some care and a respray. What is the correct and easiest way to do so? Are there a specifici sequence of which parts to remove first etc? Cheers /Finn
Finn. 1973 Morgan +8. 1959 Austin Healey 3000 BN7 2-seater. 2009 Mazda MX-5 2.0 PRHT.
I found this site a really useful reference when I was rebuilding my '75 4/4.
https://morganrebuild.co.uk/
PS
The first thing in the 'Bodywork' section is removing the front wings
Back in those days the rear wings were held on by bolts, the heads of which can only be accessed by peeling back the upholstery over the wheel arches. These days, they use threaded inserts so that hey can be accessed from underneath.
Your original bolts are going to be knackered anyway, so I recommend grinding the nuts off and drilling new holes for threaded inserts, that way you don't have to disturb the inner wheel arch covering.
The front wings are held by easily accessible nuts and bolts apart from the sections under the body tub, these are also nuts and bolts and likely to be just as knackered as the ones on the rear wings. Again, use threaded inserts when you put the wings back.
When I did this job a few years back my steel wings were very rusty and rather than attempt to restore them I put on a set of fibreglass wings from Sid Watson. Best thing I ever did to the car, Sid got such a good match with the resin colour that I didn't even have to paint them.
