7 members (+8Rich, IcePack, Image, Soleng, TBM, Mauli, JMcL),
591
34
Topics48,335
Posts812,892
Members9,203
Posts: 59 Likes: 3
Posts: 59 Likes: 3 |
Hi, I'm going to change the engine oil and not the filter on our 1973 +8. The oil and oil filter are both 1 year old, but has only been used for 3000 km. First question is if I need to change the oil after all as it looks perfectly fresh. Secondly, if I change the oil and not the filter, by just draining the sump and then immediately after fill up with fresh oil, will I lose the oil pressure and will the oil pump need to be primed? I plan to not start the engine immediately after the oil change as the car is located in a closed room for winter storage, but only after a a week or so. Do any of you have experience with Gulf 20w50 oil?
Finn. 1973 Morgan +8. 1959 Austin Healey 3000 BN7 2-seater. 2009 Mazda MX-5 2.0 PRHT.
Posts: 35,771 Likes: 468
Posts: 35,771 Likes: 468 |
I understand your reasoning I don’t think you will need to prime but when you do want to start it just remove the rotor arm and turn the engine over a few times to be safe. Gulf 20 50 is a mineral oil that these older engines operate best with although I have no personal experience of using it.
Posts: 26,746 Likes: 419
Posts: 26,746 Likes: 419 |
I would also change the filter. The cost is what under 10 quid.
If you do then fill the filter before fitting. You should run the engine to temp in my opinion both before and after draining. So I would wait till you can get the car outside.
1 member likes this:
gomog |
Posts: 7,916 Likes: 216
Posts: 7,916 Likes: 216 |
Engine oil and filter should be changed every year irrespective of mileage and with a hot engine. Oil circulating pumps don't need priming but it's a good idea with spin on oil filters to pre-fill them with as much fresh oil as possible commensurate with the angle they sit at. In the case of one that sits horizontally for example I fill to half. This to minimise time it takes the pump to fill it completely before oil pressure builds up.
gomog |
Posts: 216 Likes: 2
Posts: 216 Likes: 2 |
Include the filter. As others have said half fill with oil before fitting. And don't panic about priming, losing pressure etc, just do it and don't leave the filter off for hours! When I spoke to the boys at Techniques, this was years ago, they only had an issue once and that was because the filter, out of necessity had to be left off overnight.
Posts: 4,607 Likes: 192
Posts: 4,607 Likes: 192 |
I claim no expertise whatsoever, and the interweb is full of misleading information to prove right is wrong or wrong is right and that I have spent quite a lot of time on Morgan forums since the mid 90`s reading of the possibility of issues arising resulting in the inability to build oil pressure immediately following an oil change on a +8 and do much else, I thought to ramble on through some of it .. though perhaps best not to depend upon my failing memory...(-:
As best I can remember the general +8 advice was not to drain the oil and change the filter together but to drain and refill the sump, run the engine to ensure oil pressure built up by monitoring the gauge, shut the engine off then change the filter, and as Richard suggests, as much as might be possible put as much fresh oil in the new filter as might be reasonable and re fit it, which on the +8 is a messy business but better that than ending up with risking the inability to build oil pressure following an oil and filter change.
Sure you are mixing old and new oil in the above process, but in reality there will ever be old oil left in places in the engine to cause a degree of mixing old and new... ?
I suspect the more worn the engine might be if you warm the engine up, to thin the oil with the aim of draining as much out of the engine as possible, changing the oil filter dry, then leaving the engine sitting to allow the oil pump to fully drain down over time.... Might be the worst case scenario in terms of risking failure to build oil pressure....?
I have also read of a failure to build oil pressure after a +8 oil change where the pump gears were packed with grease in a bid to increase it`s ability to initially build pressure, which seems a tad extreme but if the pump gears are worn then I guess that could be a work around...?
It seems so much has changed in engineering tolerances and materials used and that lubricants seem to have gone through a similar process of evolution to the extent that it seems very specific lubricants may be specified for equally specific engines, and that modern synthetic oils seem to be so very different from the old mineral oils that were around when the likes of Triumph TR`s or Rovers used the engines that found their way into Morgan engine bays...?
Thin synthetic oils in a worn engine with wider clearances in it`s moving parts would seem likely to create possible pressure building issues. I think around the time that synthetic oils arrived on the scene that Castrol created their MAGANETEC which seemed to suggest that this oil would adhere to bearing surfaces and be less likely, or take longer, to drain back down to the sump as the result of a mix of time and gravity, thus risking the horrible rattle that old engines that have been laid up for months on end can develop when they fire up initially, until oil can fill all the gaps in the bearing surfaces to begin building up oil pressure...?
It seems there are some oil producers who claim to specialise in providing oils which may be more suitable for old style engines... Millers oil..? There will be others, but just how much of that might be smoke and mirrors or just business being business... I have no idea.
Much has changes since the days of removing cylinder heads to de-coke them was a semi regular task, On the few engines I rebuilt I used to spin them over on the starter motor with the coil disconnected to prevent them firing up, till the oil pressure light went out before allowing them to fire up..
It seems the mix of engineering involved betwixt metallurgy and the technological advance in oils seems to have greatly decreased the requirements for oil changes in some machinery, thinking sealed for life gearboxes on some vehicles..?
Porsche suggest bi-annual engine oil changes for the engines on their high performance machines, and are quite specific about the oils used. Just how much of that might be down to business arrangements as opposed to finding the best possible lubricant to suit their high performance engines serviceability...Matters not a jot to me, but I would not care to use any alternative.
Just to use Porsche as an example, since they went to water cooling with 911 derivative engines there seem to have been dogged by a measure of engine issues which at least one UK company have specialised in resolving, and this same company also suggest that a different oil is used in older Porsche engines which may be more suited than the oil Porsche specified when the engines were new.....?
I have run my mid 80`s +8 irregularly, only covering circa 30k miles during the 23 years I have been it`s custodian, thus it has spent rather a lot of time dormant between runs, but fortunately the old thing seems not to have suffered greatly as the result of my less than fastidious maintenance schedules relative to TIME, and fortunately for me still matches normal oil pressure expectations with the engine both hot and cold and the engine runs at a pretty standard temperature when hot, never having boiled over in my custodianship, though the driver and passenger have somewhat overheated when touring in much hotter climate zones, than here at home...(-:
As ever.... more than happy to be proven mistaken on any of the above, this is after all a discussion forum...? (-:
Yes of course we all are aware of the correct procedures involved in an oil and filter change, I answered the question that was asked for a specific reason by the OP  . Unlike me not to thread drift though
Posts: 653 Likes: 12
Posts: 653 Likes: 12 |
The best oil for Rover V8's, given their fondness for eating cam lobes and distributor drives, is one high in ZDDP zinc. I recommend Valvoline VR1 Racing 20-50. "the pump gears were packed with grease in a bid to increase it`s ability to initially build pressure". Don't ever use grease for this -- only Vaseline. The best way to get the pressure up initially is to remove the dizzy and make up a steel dowel with the slot on the end, fit it over the oil pump shaft and run it with an electric drill on slow speed. The Rover engine does not need high pressure and relies more on flow and volume. 25-30 psi max is fine. Some people fit a stronger spring in the pump bypass valve in an attempt to increase pressure -- this can lead to an even higher rate of wear on the dizzy/cam drive.
Posts: 21,865 Likes: 167
Posts: 21,865 Likes: 167 |
Having messed around with Rover V8s for 22 years, I've done all the above. Fitting a crated Land Rover engine into an MGB, after changing the front cover and pulley, etc needed just that. Vaseline in the pump gears, but you can also feed oil down the out-pipe if you spin the rotors in reverse. The BV8 has a remote filter, which doesn't help either. Even using a drill to prime the pressure it took a long time. On the matter of lubrication and filtration we had an industrial consultant of such matters in the MG Club at the time. From him you could get straight talking advice about the subtleties of 0w/30 vs 0w/40 vs 5w/30 zs 5w/40, because back in the day I was experimenting with my Roadster oils. What he also talked about was that new oil filters don't filter as effectively as those with some mileage on them. This is the filtration vs flow rate conundrum, and I suppose there will be plenty about it on the internet. I wouldn't do an annual filter change for that reason.Since a filter can take 12,000 miles of hard use, my preferred method is when it seems the right time.
Richard I find it hard to resist a ramble more so these days, as to whether that might be beneficial to anyone at all other than myself... is anyone`s guess. Griffo,thanks for the heads up on not using grease, fortunately I have not ever required to use that suggestion myself during oil changes... Dave it seems we may share a similar fondness for MGB`s in simpler times...I still like them today but back when I was looking for a more engaging driving experience at UK road legal speeds my first thought was a vintage sports car, and by good fortune ended up the custodian of a Morgan in 2002, which still resides in my garage and has been self maintained. As for the low down on oil best suited for old tec engines, I am sure I read advice from real expertise and understanding contained and discussed in great detail on the FBHVC web site some years back, I guess with a bit of rooting around it may still be accessible therein..? https://fbhvc.co.uk/
