Glitch
Topics48,331
Posts812,878
Members9,203
Posts: 1,238 Likes: 2
Posts: 1,238 Likes: 2 |
Has anyone found a lasting solution to the long travel brake pedal and the associated "mushy" brakes on MY22 Plus Fours?
Posts: 26,746 Likes: 419
Posts: 26,746 Likes: 419 |
Mine is fine. I know KH tilt the car whilst bleeding to help get all air out
Posts: 466 Likes: 52
Posts: 466 Likes: 52 |
I believe John is correct, the secret for the pedal is to get all the air out ( as always ). On our 2020 Plus Six the ABS acuator block is located under the near side wing, near the windscreen washer bottle and the swirl pot. The actuator blocks on some cars and bikes can sometimes be tricky to purge of air.. I have a hand held vacuum pump designed to pull the fluid and air through the system from the bleed point, works far better than the standard up/down of the foot pedal method. Just have to make sure someone is at the master cylinder topping up the reservoir, because it sure pulls the fluid though quickly.
Posts: 11,853 Likes: 137
Posts: 11,853 Likes: 137 |
I believe John is correct, the secret for the pedal is to get all the air out ( as always ). On our 2020 Plus Six the ABS acuator block is located under the near side wing, near the windscreen washer bottle and the swirl pot. The actuator blocks on some cars and bikes can sometimes be tricky to purge of air.. I have a hand held vacuum pump designed to pull the fluid and air through the system from the bleed point, works far better than the standard up/down of the foot pedal method. Just have to make sure someone is at the master cylinder topping up the reservoir, because it sure pulls the fluid though quickly. The best method I have found is to use a combination of a positive pressure bleeder and pumping the pedal. I have a Sealey bleeder and it's got a ginormous tank on it so no worry about running the Master cylinder down. Pressurise it up to its operating pressure and then open each nipple in turn whilst my glamorous assistant pumps the pedal in a series of rapid moves. The reason this works well is that often you can get small bubble caught in odd nooks and crannies which a constant pressure won't shift as the flow rate is still low. Add the pumping though and the additional jerk will tend to move things along nicely. I learned this some years ago when I first got the bleeder. On my first attempt I must have put 2 litres of fluid through the system but still some annoying sponginess. I went to ask my friendly local garage for advice and they put me on to the combination method. Works brilliantly and you can bleed out an entire system in a few minutes. It does depend on having a glamorous assistant to hand though. Fortunately mine is easily bribed with promises of chocolate.
2 members like this:
Graham, G4FUJ, Davetherave |
The MY22 CX has two wonderful upside down U bends above the cylinder to trap air. Another feature ![[Linked Image]](https://tm-img.com/images/2025/05/20/20240814_110701.jpg)
Posts: 28,413 Likes: 177
Posts: 28,413 Likes: 177 |
Fortunately mine is easily bribed with promises of chocolate. Chocolate is always a good move!
Sold L44FOR 4/4 Giallo Fly '09 Gen2 MINI Cooper ragtop '90 LR 90 SW
Posts: 7,891 Likes: 241
Posts: 7,891 Likes: 241 |
The MY22 CX has two wonderful upside down U bends above the cylinder to trap air. Another feature ![[Linked Image]](https://tm-img.com/images/2025/05/20/20240814_110701.jpg) Plus those awkward banjos, with blind drillings and abrupt changes of direction to trap micro bubbles
Posts: 612 Likes: 13
Posts: 612 Likes: 13 |
For an unknow reason the braking is very good just after washing the car. But after two or three braking it is again soft. I am even able to activate the abs wich never happens when a drive the car.
Posts: 193 Likes: 5
Posts: 193 Likes: 5 |
Probably rust on brake discs.
1 member likes this:
Hamwich |
Justement je fais un petit tour après le lavage pour éviter la rouille. Et la pédale n'est pas du tout molle et ne s enfonce pas.
