9 members (Image, Joe Speetjens, Tweed19er, Alanv60, Methodical Ninja, JohnHarris, vbalddave, MartinB60, John Winn), 302 guests, and 22 robots.
John V6 83
+8Rich 69
DaveW 67
Luddite 57
9,203 Registered Users
by Oskar - 20/07/25 04:13 PM
Goggle eyed
by Roady - 19/07/25 06:16 PM
by t50 - 19/07/25 12:07 PM
Lions Tour
by OZ 4/4 - 19/07/25 11:55 AM
Morgan rebuild on Facebook
by TBM - 19/07/25 10:50 AM
by Nick B - 19/07/25 10:22 AM
Topics48,335
Posts812,890
Members9,203
kamo30
Thread Like Summary
Total Likes: 1
by Crowbar
Crowbar
So while changing my badly worn, sloppy, clutch linkage, I found this:
A pretty impressive notch on the RIGHT side of the bellhousing slot for the clutch release...
I've heard that the motion of the spinning clutch can lead to a notch on the LEFT side of the bellhousing slot - I'm curious as to what caused this impressive notch?
I'm thinking of using the stainless metal plate repair fix described here: https://madaboutmorgans.com/reconditioning-the-4-clutch-release/ as a solution, but using it on the RIGHT side instead of on the LEFT (as described in the link above).
Questions:
1) Do you think the plate fix described in the link can be done with the bellhousing in the car? I think I could get a dremel in there to widen the slot to accept the plate, but I'm worried about the metal shavings left behind.
2) What causes the notch on the RIGHT side?
3) The clutch action feels fine to me, is there any reason to correct this - or should I just live with it?
As always, many thanks.
-GC
Liked Replies
by sewin
sewin
Well after Arwyn's advice I think I would agree with your last decision but I might ask them to install the stainless rub plate as well. High magnesium alloy is really hard to weld and even a good tig welder would fail, It pops and splatters everywhere! and doesn't stick!
However you decide to do things, Arwyn is probably the best opinion you will find. Best of luck crowbar.
1 member likes this
