6 members (John07, MATTMOG, GrandadC, High Hamster, JohnHarris, AlyMatt), 305 guests, and 41 robots.
John V6 83
+8Rich 69
DaveW 67
9,203 Registered Users
by Oskar - 20/07/25 04:13 PM
Goggle eyed
by Roady - 19/07/25 06:16 PM
by t50 - 19/07/25 12:07 PM
Lions Tour
by OZ 4/4 - 19/07/25 11:55 AM
Morgan rebuild on Facebook
by TBM - 19/07/25 10:50 AM
by Nick B - 19/07/25 10:22 AM
Topics48,335
Posts812,889
Members9,203
kamo30
Thread Like Summary
CooperMan, JohnHarris
Total Likes: 3
by Grumpy2
Grumpy2
Fitted BRBs as part of the front end and they significantly foul the flexible brake lines. I have my MOT booked in later this week. I think this will clause a fail. I can’t see another solution other than removing the BRBs or a significant repositioning of the hard and flexible brake lines. I’ve tried running the flexies over the BRB but tats even worse
Thoughts welcome
Liked Replies
by Arwyn Williams
Arwyn Williams
Originally Posted by Arwyn Williams
I don't think that is actually a fail, at worst, possibly an advisory.
My reading of the Testers Manual is that the flexi has to show serious damage when presented for it to be a fail.
Looks like you have mitigated against damage to the flexi by splitting the rubber tubing and cable tying it to the flexi.
When I fit them. I'll position the brake reaction bars in such a way as the sidewall of the tyres will not rub on them.
Arwyn
Arwyn,
How do you achieve that when fitting the BRB, my 4/4 70th and Roadster had BRB's fitted and both rubbed on the tyre sidewalls and reduced the lock.
Simple, I didn't buy ready made ones , made my own and also filed away at the bottom mount to bring it closer to the inner wing....
Arwyn
1 member likes this
by sewin
sewin
John, You have to make your own BRB's. Either adjust the length or you can ,if its an old narrow body bend the bars with an inward angle to clear the tyre on full lock. use an old wire coat hanger to determine the point at which you make the bend. I do use a pipe bender to make the bend and protect the tube and the deformation has no effect on the function of the BRB. The BRB's are made such as to protect the chassis should the cross-head take an impact in that the chassis rear mounting point should suffer little damage in that event, you could say that a modified BRB in the way I have just described will have a natural fold point thus aiding chassis protection even more.
Having always worried about the resultant chassis damage from impact to the front of the car on the rear BRB mount I have for the last two years been using brass bolts and stainless nylock's on the chassis end and there seems to be no detrimental damage to the bolt in use. I had expected to change them annually but on inspection they seem fine. My prompt for this solution was that when the BRB's were first marketed they had bolts supplied that were stated as shear-able in the event of frontal impact but now they seem to be supplied with high tensile steel versions, I think the chassis would suffer damage were these used and an impact occurred. Perhaps the tube SWG rating is thinner than the originals and the tube expected to collapse before damage takes place but I don't want to chance it!
1 member likes this
by Grumpy2
Grumpy2
It still goes under BRB, full and free lock to lock with sufficient clearance to allow for suspension travel
1 member likes this
