5 members (DCH, TigerTim, Haggispeed, Lionel Mandrake, TBM), 320 guests, and 42 robots.
+8Rich 95
John V6 52
Posts838,013
rockabilly john
Ale_72 Offline OP
Under the rain. Expectations vs reality
Not too much to be added. doh
19 Comments
A WA owner found it was the rubber seal around the frames and the way it was fitted in the "corners". Seeming that was an easy fix...
Ale_72 Offline OP
As soon as it stops raining I'll check it. Thanks for the hint!
If you PM MadMax I am sure he can fill in the blanks.
Ale, is the boot leaking or the targa roof?
If it is the roof, I seem to remember Andy or Brian mentioning that there was a technique to putting the panels in and if it wasn't followed, there were leaks.
Ale_72 Offline OP
It is the boot.
Or better it is even the roof, but there are just a few drops, so I am not worried at all.
Biggest leaks are in the boot. I'd say from the farest part of the boot (next to the end of the car).
Since the bottom of the boot is not flat, then the water "moves" to the part next to the gas tank.
Assuming the seal is not damaged, it should be relatively easy to adjust the boot lid to get a good seal. If you put some silicon grease on the under side of the boot lid where the seal fits, then close the lid you should be able to see where the grease has transferred to the seal or not. This should give you a guide as to where adjustment is needed.
Martin (Deano)
Ale_72 Offline OP
Thanks!
I'll give a try as well.
My only doubt is that, since to close it you have to push it harder and then the lid goes back to position, probably you will "misrepresent" it.
This is all very well but these cars cost around £130.000.00 !!!!
Reg
Reg
I've dropped MadMax an email. He'll be along shortly.
