4 members (Gordon D, Mark+4, Graham, G4FUJ, +8Rich), 255 guests, and 33 robots.
+8Rich 94
John V6 50
Posts837,997
rockabilly john
3 Images
Soleng Offline OP
Air suspension for fourseater Morgan Plus 4
Today I picked up our 2008 Morgan Plus 4 fourseater from Bråthen Bil where Trond Bråthen had fittet a set of two additional dampers with built-in air springs and an on-board compressor. The compresssor is controlled by switches hidden under the dashboard.
Air springs are inherently progressive. Since it snowed today, I have not had the opportunity to test the car with passengers, but the first drive was impressive. The comfort level was far beyond my wildest expectations, and at the same time the car felt more stable and planted. Speed humps can now be traversed at normal speed. All in all, this seems to be a very good upgrade.
Harald
P.S. Photos by Trond Bråthen
20 Comments
What a brilliant idea. I would love to be able to keep the current ride height on my car on the road but be able to raise the ride height when needed, not just speed humps but getting it into the garage without scraping the underneath of the car.
Andrew
'Alice' 2013 Duratec Plus 4. Pearl Blue
Having had air suspension on a couple of motorbikes I can fully understand the improvement, it was superb and made a heavily laden motorbike handle really well and the possibility to 'trim' whilst riding along was a very nice feature, nice and stable on autoroutes and yet more 'flickable' (relative statement) on the twisting.
BR Colin
That wiring wants a bit of a tidy up... smile
I think you may have the first application of air suspension on a Morgan.
Martin (Deano)
Soleng Offline OP
No, it is not the first. Trond Bråthen made a similar conversion on a four-seater Roadster some years ago.
Harald
Harald
Soleng Offline OP
Yes, but the photo was taken before the compressor had been connected. smile
Harald
Harald
Well pimp my ride laugh2
Graham
Interesting. I have seen car modification shows on TV where air suspension has been used as a " pimping " option.
Could this system be a mod for Morgans and make Suplex redundant?
There appears to have been a lot of developments to Morgan suspension around the basic sliding pillar system - Mulfab/Suplex etc.
Peter Mulberry developed an I dependant front syste.
Air system looks like a break away from a standard thought line of spring changes etc with a new approach.
Be interesting to see how it stands up to extended use and development to offer variable set up as per the present damper adjustment options.
I'm very happy that Harald decided to go for this rear end conversion, which Trond Bråthen at Bråthen Bil (www.bbil.no) in Norway and myself designed 3 years back.
I took delivery of the first production Roadster 4-seater (which really is a contradiction in terms) in august -06. This really is what I would call a "Thinking Mans Morgan". Very quick and very practical. The only problem being that the factory really didn't get it right the first time!
Having bought some cars new from the factory, I use to say that a new Morgan is a good starting point. I used more than £ 15.000 to make my LeMans +8 as I wanted it (seats, engine management, hood, suspension), and I had hoped that this would not be the case with the Roadster. Oh boy, was I wrong!
Before I start let me just say that I love the engine. So quick and easy to live with. (btw, I really envy the guys who has the Cyclone. must be even better) The first thing I noticed right away was the handling, or rather lack of handling. Very unstable in a straight line, very unstable during long sweeping bends, very low, very soft (we're talking front end here) and generally very bad. I drive a 1934 3 wheeler SuperSport that is much better handling, all concidering. The rear end was also very soft, and every time I did a brisk acceleration, the axle would rotate so that the drive shaft would hit the tunnel making a terrible noise. Didn't take long before the U bolts broke as well.
Then there is the tank filler. The first time I (tried) filling her up, I lost a gallon of fuel on the ground ( and on my trousers). If I were to get the fuel in, I probably would have to use 20 minutes on the job. Being less than patient, I never tried... (The guys at the factory never acknowledged this as a problem, but on newer 4-seaters you will see that they have changed the design of the filling system)
Having had Morgans for 20 years, I have had much business with Trond Bråthen, the most experienced Morgan mechanic in Norway. We have spent many hours contemplating improvements to my cars, my Roadster having been most time consuming.
We started with the filler-problem as this was most acute. After having made 2-3 attempts with larger diameter tubes, better breathing etc, we have finally found a system that works reasonably well, as long as I turn the filler-grip 70 deg and fill it with some care. If you recognize this problem, feel free to contact me as I won't do any details here.
Then for the suspension. Trond is doing quite some business with Peter Mulberry at Mulfab, and we decided to try his new front suspension (http://www.mulfab.co.uk/our-products/48/steering-suspension/front-wishbone-conversion )
It works wonderfully! The only problem is that it gets a bit heavier on the steering wheel at low speed as the tires are so much better in contact with the ground. My next project is to install an electrically assisted steering column. This is virtually bolt on, and should be relatively easy to install.
Then there was the rear end. We tried to address 3 issues: Ride height, suspension action and rear axle stability.
On the early roadster 4-seaters there really isn't much room to play around in so we decided to try and catch several birds with one stone. As you have seen, we landed on the solution of using an additional set of dampers, and using pneumatic ones to address the very different loads there are with and without passengers and luggage.
As Harald stated, the result is magnificent. The extra set of pneumatic dampers not only stiffens up the rear suspension and makes the car more stable, but it works as a reaction rod keeping the axle from rotating under acceleration. As for the ride height, this is mostly a problem in the front, and pumping the car up at the rear really doesn't help much. Trond and I have other plans how to deal with this problem...
Having tossed around ideas on how to make my Morgans behave better while trying not to "de-mog" them, I've found that there
is really little help to get from abroad. Mulfab is a very good place to start, but otherwise my experience is that we do very well here in Norway. Trond Bråthen has a wealth of experience, and he an I have done quite a lot of things that are a first in the Morgan Community, pneumatic dampers being just a small part.
Regards
Bjørn Schage
1934 Matchless SS
1960 +4 4-seater
2002 +8 LeMans
2006 Roadster 4-seater
2014 M3W
and some other non-Mogs
