0 members (), 384 guests, and 93 robots.
Topics49,847
Posts837,389
Page 1 of 7 1 2 3 4 5 6 7
#149040 12/08/13 02:39 PM
PeterG Offline OP
Had a day off today, apart from washing and waxing. I added some sound proofing material to the rear of the seats to reduce a really annoying flapping noise at the low speeds. It's now more of a flip than a flap wink
PeterG #149042 12/08/13 03:03 PM
HJP Offline
That'll probably help stop water and debris getting through as well , I taped over or siliconed the gaps which largely cured the problem .
I wonder what is causing the flapping noise ? It's not something I've heard with mine.
Hugh
PeterG #149046 12/08/13 03:09 PM
Q
Q
Just wondering,can you/is it faster to remove the bevel box this way,or you have to remove it from underneath the m3w?
HJP #149066 12/08/13 04:32 PM
PeterG Offline OP
I did try to cover the gaps. Checked everywhere for the noise nothing loose can only presume its a cable flapping, tapping on something. A lot quieter now.
PeterG #149076 12/08/13 05:03 PM
I think Blake took his whole car apart and Dynamatted every possible surface! (There's a post on LED light conversion where he dynamatted the inside of the headlight pods!)
All kidding aside - this sounds like a really good idea...I suspect doing the inside of the boot and forward compartment with further elimate all the rattles...
1965 Plus 4
2008 997 Turbo Cab
1981 Alfa Spider
1954 Austin Healey 100 (SOLD)
2013 M3W (SOLD)
Crowbar #149288 13/08/13 01:34 PM
Ditto. Was a very worth while endeavor. still haven't gotten a chance to post the write up but i'll tease with these two pics that shows some, but not all, of my dynamatting madness.
blake
sfmorgan.tumblr.com
Blake #149294 13/08/13 01:54 PM
AQM Offline
Makes me wonder* how much better a honeycomb or foam sandwich CF or Kevlar panels would be (and with weight savings to boot).
*If one has the skills. But the shape of the panels (and even the fuel tanks) aren't really complex. Although not cheap, one could buy already made sandwich or honeycomb panels, cut them to size, epoxy the perimeter and then install.
AQM #149404 13/08/13 09:50 PM
Neat work Blake, as ever.
@ Blake:
sweet job!
Do you really recognize a difference?
How big is the difference?
Worth the effort?
Blake #149709 15/08/13 10:17 AM
PeterG Offline OP
Your clearly better at the sticky backed platsic than me, very neat job.
