Topics48,381
Posts813,568
Members9,215
Posts: 201 |
Rear fog/safety light adjoining number plate stuck on.
Wish to isolate it but no schematic of fuse layout supplied with car.
Any ideas?
Thanks in advance for any tips.
-------------------------------------- Regards Bob
Posts: 5,113 Likes: 57
Black Rat Charter Member
Posts: 5,113 Likes: 57 |
Why don't you take the bulb out ?
Posts: 21,872 Likes: 168
Posts: 21,872 Likes: 168 |
Fuses:
Primary Box: 1 30A Ignition Switch 2 30A Starter Relay 3 30A Fuel Pump & Ignition 4 40A Cooling Fan 5 30A Air Con 6 20A Dash Module 7 20A Engine 8 20A Main Fusebox
Main Box: 1 15A Engine .............. 11 7.5A Nearside Sidelights 2 15A Engine .............. 12 7.5A Offside Sidelights & Dash 3 15A Engine .............. 13 7.5A Nearside Dipped Beam 4 5A Dash Module ........ 14 7.5A Offside Dipped Beam 5 7.5A Rear Fog ........... 15 10A Main Beam Nearside 6 15A Demist .............. 16 10A Main Beam Offside 7 15A Heater .............. 17 10A Radio & Courtesy Light 8 10A Wipers .............. 18 15A Sidelight Switch & Cigar Lighter 9 10A Radio & Horn ........ 19 15A Fuel Pump 10 15A Indicators & H/L Flash ........ 20 15A Reverse & Brake lights
Posts: 201 |
Thanks Dave. Very helpful.
Keith, an elegant solution. Thanks.
Posts: 14,723 Likes: 151
Posts: 14,723 Likes: 151 |
I published some diagrams of fuse and relay layout that may be useful on the following thread: http://www.talkmorgan.com/ubbthreads.php/ubb/showflat/Number/228196You can download the pdf that I attached to that thread, print it, and keep it in the car for reference if something blows whilst you are on the road.
Posts: 82 |
where are the fuse boxes located ? i only see one on the firewall gr tom where is the second one
The large fuse box on later cars is under the dash above the handbrake & gear lever. Beware that some fuse boxes may vary in layout of what fuse does what job.
