3 members (Morganmike, Julian BB, John V6), 435 guests, and 41 robots.
+8Rich 71
Adam12 69
John V6 55
9,215 Registered Users
Goodwood Speedmog 2d august
by Nick55 - 01/08/25 09:09 PM
Walnut Dashboard
by +8Rich - 01/08/25 06:24 PM
SORN
New
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
Pedal mod
Pedal mod
by RibbleAdventures, July 31
4/4 80 Anniversary Rex_Tulips
by Rex_tulips, July 31
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,372
Posts813,496
Members9,215
Page 1 of 7 1 2 3 4 5 6 7
JVS Offline OP
Draggin found this oil cooling solution
Compete kit just need to modify the bracket.
$399 dollars - even on eBay
http://www.thunderpress.net/motorcycle-r.../2013/05/23.htm
Another link to a video from the factory, it's the first segment of this TV show
https://m.youtube.com/watch?v=Uk6QkgHZSFY
JV Sclafani
Boca Raton, FL
'13 M3W Metallic Orange Pearl
128CI Steered by Empire - Riding on Ohlins
Thanks for the props! I like this one because you could put it outside of the normal air flow the fans would take care of moving the air around only once the oil was up to operating temperature.. Also my concern with having the oil cooler out in front all the time is on a colder day where you might want the oil to warm up a little faster having it hanging out front might prevent that?
kirkusblog.com
1952 Ford 8N
JVS Offline OP
Maybe cyclinder fan spot cooling over oil cooler
Below are three different fan systems
Love Jugs air fans
Maybe fitted on the backside of the cylinders (jugs)
https://m.youtube.com/watch?v=bUt1ILH6t2A
https://m.youtube.com/watch?v=Wencsm0VGa0
Fix My Hog free channel - newer smaller model "Cool Master"
https://m.youtube.com/watch?v=3DtWoGcfibo
https://m.youtube.com/watch?v=Lw3XXq__gSU
Another smaller twin fan setup which looks nicer
http://wardspartswerks.com/cooling-fans.html
https://m.youtube.com/watch?v=tAmaGOromiY
Single cyclinder fan
https://m.youtube.com/watch?v=BjRCBPygFnA
JV Sclafani
Boca Raton, FL
I like it ! shades thumbs cheers
2013 M3W # 793
'Mosquito'
I have been running a set of Love Jugs for over a year now. I have a manual switch and turn them on when traffic drops to a crawl or stops. I made a bracket that mounts them roughly center rear side of each cylinder about an inch away. I thought about adding a head temp transducer but never got around to it.
Sent an email inquiry, Earl Sutton says he sold two to M3W owners. C'mon guys, fess up, who and how ... thinking
thumbs cheers
2013 M3W # 793
'Mosquito'
JVS Offline OP
Thanks for the information about your testing of the "Love Jugs" twin cooling fans rolsmith, good to know it works for you. Since you live in Arizona, hot and dry in the summer your M3W really needs air moving over the engine fins for cooling when in-traffic.
I would think that only a fan system will cool an engine when stopped or crawling along in traffic. Where as the oil cooler will increase the motor's durability by cooling all of the rotating parts in the crankcase. The combination of the need for instant cooling of the heads and cylinders along with the constant cooler oil should be the best engine insurance possible.
JV Sclafani
Boca Raton, FL
Talked with the lads at S&S when the 'cooling kit' was developed. Fan blows on the back side of the cylinder heads, which is out of the wind. Makes sense. But I agree, JVS, I prefer an oil cooler for all the same reasons ...
thumbs cheers
2013 M3W # 793
'Mosquito'
Is there any reason you could not just fit an oil cooler on the return pipe from the scavenge pump to the oil tank? I am thinking of fitting mine behind the grille. Because it is behind the cylinders and getting hot air off them, I would need to fit a bigger cooler than one would normally fit but there is no shortage of space. Since fitting the G56 Stage One kit and uprated ECU, the oil is getting noticeable hotter, simply because the car is so much nicer to drive quickly.
Wilson
I had similar thoughts expecially since my car has the new bonnet louvers
kirkusblog.com
1952 Ford 8N
