8 members (Rex_tulips, +8Rich, B&C Morgan, BobtheTrain, nick w, howard, RichardV6, Grumpy2), 326 guests, and 26 robots.
+8Rich 64
Adam12 62
John V6 58
9,215 Registered Users
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Pur Sang Type 35
Tom Lehrer RIP
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,362
Posts813,329
Members9,215
Page 1 of 5 1 2 3 4 5
I have made quite a few swerves and u turns in my efforts to sort out the drive train and so here is a concise, not necessarily chronological, account of my research, modifications and findings.
My machine is a 2013 model with Centa drive coupling and NVH kit fitted before I purchased it in 2015 with 625 miles on the clock from new.
The problems to be cured were the need to rev the engine hard on pulling away to avoid clattering and banging and the loud bangs and jerking when accelerating hard. Also addressed were the fierce vibrations at 3,000 rpm in higher gears.
I firstly replaced the final toothed belt drive with a chain. This had benefits in reduced cost to replace, simplicity of changing the overall gearing and quieter running. This did not, however, cure any of the problems mentioned above.
I replaced the barrel shaped rollers in the Centa drive coupling with polyurethane blocks made to fit precisely in the recesses in both rotors. This cured the pulling away issues but not the big bangs on acceleration. These blocks have subsequently been modified in shape to give a little more shock cushioning but still not the free play found when using the originals. After 1,600 miles of hard test driving there were absolutely no signs of deterioration of either the inserts or the surfaces of either rotor.
I fitted a front bearing to the shaft which supports the Centa coupling and clutch as I thought this would improve the life of the single standard bearing and help with vibration damping. This has probably only brought about minor improvements to the vibration but I still think it worthwhile for the longevity of the set up.
Much of the vibration stemmed from the so called NVH kit. The front of the bevel box was found to lift and therefore transmit vibration through the final drive to the rear wheel. I discarded the NVH kit and re mounted the bevel box directly to the chassis using clamps with 2.5 mm. thick polyurethane liners to isolate the high frequency whine from the bevel box ( this was presumably the purpose of the NVH kit ). I made and fitted a third mount extending up to the cross member behind the seat backs. This has eliminated all serious vibration problems. The bevel box still whines but I do not think that is an issue which can be resolved by external modifications. The surprise is that this has also completely eliminated the banging on hard acceleration. I confess to not knowing why but I think the front of the bevel box lifted to a greater degree than I had managed to observe and then would snap back down on to the chassis with a bang and resultant hard jerk to the final drive.
Prolonged road testing has proved the entire system to be safe, reliable more comfortable and the vehicle more pleasing to drive.
To read my reports on the whole process including pictures please go to www.bleazey.co.uk and click on the picture of my Morgan.
If there is interest, I would be prepared to make a preliminary, small batch of kits to include new polyurethane coupling inserts, the bearing and stub shaft for the front end of the coupling and a full set of bevel box mounts. The chain final drive is not something I think the average owner needs to worry about, a new steel rear sprocket seems to be the answer to early failure. I would endeavour to supply instructions for the entire installation procedure from start to finish for people to follow themselves or to pass to their chosen garage mechanic. Do, please, let me know your thoughts on this.
All the best,
Phil
Wow, you have done a lot. A very impressive website
2025 MG ZS EV aka Trigger
Hi Phil, i have been reading with interest all you posts over the last year or so.
What in interests me is your bevel box top mount that you have fitted. It looks like it bolts to the bevel box and adjusts to the cross member above it.
Does this give much improvement to the drive of the car? How much would this cost to make?
Also, your centra poly bushes. Can you just replace them or do you need to rework the internals as well?
....Phil your an ole school hot rodder! Thanks for sharing.
High Noon Speed Shop
Blog: https://ontheroadtonowhereville.wordpress.com/
Hi John, I have not tried the machine without the top mount yet but it is only a very small job to do so and if it is not needed then all well and good. I would however not fit it with the Morgan NVH kit as the support from that kit is very poor and my top mount would be taking all the load and vibration. Certainly the most important mounts are the bottom ones. As to costs I will wait to see what interest there is and then work it all out.
The Centa inserts just slide in in place of the originals - no messing about.
Impressive stuff.
Thanks for a prompt reply Phil.
JVS Offline
Hi Phil,
I'm interested in you kit.
How much and when can it ship?
I have the Orange Carrot engine and transmission
apart for the second time, first was to replace the clutch slave unit and full clutch.
I'm replacing them again since everything is apart in trying to trace down a bad noise somewhere in the drivetrain. I also wanted to get the transmission services since I had ground down the 3rd gear synchro trying to get her home while the clutch salve was going bad. What I have found is that it's not a simple thing to rebuild as this is NOT a regular Mazda Miata transmission! It's a custom housing along with custom internals. This transmission has different blocking ring setup using dual rings for 2nd and 3rd gears. No one in the USA has ever seen this setup so I'm trying to find a UK Mazda race shop but I think this is another expensive Morgan only part that you have to source from Morgan.
I think I'll just have to match rev shift 3rd gear for now.
Cheers,
JV
JV Sclafani
Boca Raton, FL
'13 M3W Metallic Orange Pearl
128CI Steered by Empire - Riding on Ohlins
Originally Posted By JVS
Hi Phil,
Cheers,
JV
Hi JV?
Sorry to hear of your gearbox troubles, I think Morgan use a lot of tied components which can only be sourced direct in order to maximise profits!
I will put your name top of the list and let you know as soon as I have prices. One thing I have to consider is the production of tooling to get the Centa inserts moulded. If interest is low I will have to make them by hand. It may be a couple of months before I can ship I'll keep everyone posted.
Thanks so much for your interest.
By the way, did you find out who makes that clutch?
Phil
Hi Phil
Very interested in all items, please add me to your list .
Cheers
Graham
