7 members (linklaw, +8Rich, Adam12, RichardV6, TBM, Lordofthewings, DJC),
288
40
New
Topics48,365
Posts813,372
Members9,215
Posts: 1,211 Likes: 21
Posts: 1,211 Likes: 21 |
I'm going to attempt replacing the handbrake cable on my 2014 plus 4 tomorrow due to a cracked outer skin on the offside. Common problem I believe.
Anyone tackled this before and can give any useful advice? I know it's a bit of a pig to do and requires removal of the tunnel.
TIA
Gordon Duguid 2014 Duratec engine plus 4, Montreal blue.
Posts: 296 Likes: 4
Posts: 296 Likes: 4 |
Hi Gordon, it's not too bad a job. I take the seats out then remove the bolts on one side of the tunnel. I loosen the bolts the other side. At this point I can prop one side of the tunnel up with wooden blocks and get my hand in to undo the cable fixings, in my case pipe clips screwed to the floor. I have heard of people punching the screws out from below but I don't know how they fix the cable back and it sounds a bit destructive to me. Mine is a 4seater and I was given the wrong length cable initially which was a bit annoying! When you finally adjust the cable don't forget to release the automatic adjustment on the rear brake shoes before you start. I found a 3/8" drive deep socket is much quicker than a ring spanner when tightening the cable. Gomog has info on handbrake adjustment. Good luck.
1994 +8, BMW Calypso Red. 2002 4/4, 4 seater, BMW Calypso Red. How do you open the boot?
Posts: 305 |
The outer casing cracking is a common fault as you say , I found a break in the outer cable just above the bent in the cover at the brake drum .I soaked the area with ACF50 and then sealed it using plumbers tape . This was 2 years ago and if I have stopped the inner cable from rusting it should not fail . I also try to lub the cable from the top .
Jimmy 2015 4/4 Sport Green 2018 VW Tiguan 1969 Morris Minor Traveller 1960 Morris Minor Saloon
Posts: 305 |
Morgan should have taken a lesson from Morris Minors they have a grease nipple half way down each cable .
Posts: 1,961 Likes: 43
Posts: 1,961 Likes: 43 |
The outer casing cracking is a common fault as you say , I found a break in the outer cable just above the bent in the cover at the brake drum .I soaked the area with ACF50 and then sealed it using plumbers tape . This was 2 years ago and if I have stopped the inner cable from rusting it should not fail . I also try to lub the cable from the top . Likewise. I used denso tape and that was almost 4 years ago. A lot easier than replacing the cable...only to see it crack again!
Posts: 5,056 Likes: 318
Posts: 5,056 Likes: 318 |
Self-almalgamating tape would likely make a decent sealing job too .... easy enough found at an electricians suppliers (or I think I got my last roll from Ewn in Peterhead )
Ps ... if you were keen to get it done over the weekend I have some here.
Posts: 26,763 Likes: 425
Posts: 26,763 Likes: 425 |
I must admit I would treat with oil then clean the outer & apply some duct tape followed by a slit rubber hose held on by tie wraps to protect it.
Posts: 296 Likes: 4
The above procedures will delay the inevitable but eventually the cable will rust and bust!
Posts: 890 Likes: 29
Posts: 890 Likes: 29 |
Looks like tape would not have done the job...
Pay attention when reinstalling the tunnel. Correct alignment ´prevents the shaft touching in hard cornering.
Otherwise you start from the beginning;-)
1985 plus 4 four seater 1992 Peraves ecomobil bicycles (pedersen to recumbent)
