7 members (Lord Sward, Paul2408, JohnHarris, Stevo666, SCX358G, IcePack, DickJ), 168 guests, and 122 robots.
+8Rich 103
John V6 66
Factory meet
Diss Festival of Transport
Goodwood
My 4/4 as it was in 1975
US Cars - Metric Threads?
by Paul F - 17/09/26 08:29 PM
Nice hardtop
First Morgan as it is now
by Strathaven, September 15
Topics49,931
Posts838,505
AlexCreasey
DaveW Offline OP
Apparently there have been cases with the 4 cylinder Zetec, where water has come in through the louvres and caused a misfire. Although the Roadster coil pack is high up at the front of the engine bay, any water which gets in can run down the HT leads and may cause a misfire. So for a while I've been wondering if a coil pack cover is feasible. thinking
In the end I turned to Origami......
Next I turned to the scrap box where I'd salvaged some aluminium from an old shower. Out came the snips, and hey presto.........
Then came the tough part - the folding. I must be getting better, because one attempt produced this:
The centre fold will locate between the two rows of HT lead caps.
Next, after some shaping with a hammer, and a trial fit:
Next the lining. 4mm standard density neoprene over the centre fold to locate the shield, and 3mm on the horizontal sections. There is a slight overlap all the way round. No chance of an HT short with this insulated lining.
Another trial fit..........
More to follow>>>>>
DaveW Offline OP
Next I applied the outer cover, using high density neoprene,which keeps the shape better..... using aerosol adhesive. This overlaps the aluminium former by quite a margin as you'll see next.
Underneath - where the 'overlaps' will be subject to engine heat I've applied Reflect-a-Cool adhesive heat barrier, and you should know by now where I get this stuff. It's looking quite good........
A final trial fit:
It's a push fit, and holds in place very well, but next a road test is needed to make sure it stays put, and doesn't get too hot. thumbs
South Wales Correspondent
Dave,
AS soneone who has had water ingress problems with a 4/4 Zetec, I read the post and the pics with interest. Looks a great idea.
regards,
GLLHG
Dave, nicely done, my HT leads look a bit naked now, I'll have to get snipping.
No water ingress with my 4/4 Zetec as it only has 12 louvres per side!
What about a deflector plate fixed to the underside of the bonnet, under the louvres to channel water to the sides, rather than over the cam cover?
Nigel
Originally Posted By GLLHG
Dave,
regards,
Try the shropmog website it has a fix. I never bothered but I know water always got in there.
http://www.shropmog.co.uk/ See the Technical section
DaveW Offline OP
Post Photobucket Reboot from March 2010:
More to follow>>>>>
DaveW Offline OP
A final trial fit:
2017 Note: This is still in place and doing the job.
