Topics48,337
Posts812,917
Members9,203
Posts: 1,664 |
Just posted to the internets today! Great review, again nothing ground breaking but these guys put out reliably good information about all things current in the automotive world. Enjoy! 2013 Morgan 3 Wheeler First Drive Two Cylinders, No Doors, and Absolutely Irresistible
August 14, 2012 By Paul Horrell OK, so it's not technically a car. But after exposure to the Morgan 3 Wheeler, any car fan will fall in love. Its charms may seem simple or even crude, but it's absolutely irresistible.
Two cylinders. No doors. A curb weight around 1200 pounds. Yeah, yeah, we all know minimal specs are often a route to maximum fun. But three wheels. Three wheels? Surely that's taking the concept of reduction just a little too literally.
When it comes to three-wheel motion, there's all the difference in the world between the wrong and right placement. The idiotic way is to have the single wheel at the front. That was practiced by England's Reliant Robin and famously debunked by several instances of toppling-over on the U.K. "Top Gear." The right way was practiced by another English company, Morgan, in great numbers from 1919 to 1950. It's to put the singleton at the rear.
So now it's back. The history is convoluted but charming. Starting a decade ago, Pete Larsen, of Liberty Motors in Seattle, almost single-handedly developed a machine inspired by those old Morgans. Word got back to Charles Morgan, grandson of founder HFS Morgan. He loved the thing, and took the design back home to England for extensive development. Liberty is now one of the U.S. distributors.
But why revive the Morgan 3 Wheeler at all? As a practical everyday car, it's basically useless. Charles Morgan himself completed the coast-to-coast Gumball 3000 rally in May of 2012, but it must have taken real fortitude in the face of heat, sunburn, cold, wet weather, vibration, wind, and cramp.
You might think that since it's a skeletal lightweight, it would be best classified as the kind of car writers tend to call a "track-day weapon." But no. Four-wheelers would run rings around you through any corner.
Instead, where this car weaves its profoundly magical spell is in turning an ordinary road drive -- at sane road speeds -- into something involving, memorable, and exhilarating. A happy time indeed for you, and those who see you.
Straddling the front wheels is a 2.0-liter 'X-Wedge' V-twin from Wisconsin bike-engine maker S&S. It's an intriguing motor, with a 56-degree V-angle rather than the traditional 45 degrees to allow for bigger pistons. Three camshafts lie in the crankcase, a shared central unit for the inlets, and a pair of outboard shafts that serve an exhaust valve. This allows for pushrods that run near parallel to the valves.
Its torque peaks at 3250 rpm, and it's not that short of violent at full song, so output is smoothed by rubber cushions before being passed to a five-speed gearbox cribbed from a Mazda MX-5 Miata, via a belt to a bevel drive to the rear wheel. No need for a differential when there's just one rear wheel.
Under that beetle-backed sheetmetal, the rear wheel is suspended on a bike-type swing arm, and wears an automotive 175/55, 16-inch tire. Nakedly on view to the world, the front suspension is a double wishbone setup fitted with 19-inch tires only 3.5 inches wide.
The frame is tubular steel, and what little bodywork it carries is aluminum sheet. The instruments sit in beautiful aircraft-style modular weatherproof housings. Switches and the column stalk are milled aluminum. Nothing seems borrowed or out of place.
Getting access to the driver's seat is a gymnastic maneuver not without peril. If the car has just been running, take care not to burn your calf on the hot exhaust pipes that run along the sides of the car. If you avoid that, the gear lever awaits to ambush your pant leg.
Persist -- it's worth it. The starter button lurks behind a little hinged safety latch. Morgan calls it a "bomb release" cover. In the same vibe, the accessories catalog contains Royal Air Force roundel stickers. But really all this handlebar mustache comic-book military stuff is a distraction. This car is about having some non-aggression in the modern era.
The motor shudders into the typical chugga-chug-chugga idle of a big twin. Early press cars had higher outputs, but this production form makes roughly 80 horsepower at the rear wheel (around 90 at the flywheel). You drive on the generous plateau of torque, relishing in its instant, eager, tuneful response to any movement of the throttle pedal.
Sure, 80 hp isn't normally the stuff of eye-watering performance, but your eyes do water, in part because of the wind buffeting, but also because the whole car weighs less than 1200 pounds. Morgan claims a 0-60 mph time of under six seconds. What makes this so joyful is that 60 feels like 80, or 100. We can only imagine what its 115 mph estimated top speed feels like.
And then there's the handling. The front tires are super-pointy, yielding garrulous feedback to your hands. You saw at the wheel with no power assistance provided or required, making room for your elbow by hanging it out over the side. Poke the throttle vigorously in a tight bend and out comes the rear end (there are no electronic nannies on this car), but it's easy to grab it back in with a tweak of the wheel. Contrary to expectations, the car exhibits little if any body roll.
And so you barrel down the road, saturated by the cues of the 3 Wheeler's motion. There's the noise, the air stream, the intimate but not harsh ride, the smell of hot oil, the sight of the front hub-mounted fenders bobbing up and down in your peripheral vision. It's not the tidiest way to get along, but it sure paints a broad smile on your face.
A sane mode of transport? Hardly. The fastest way to get around? Nope. A life-affirming recreation and a release from the cares of 2012? Absolutely. http://www.motortrend.com/roadtests/convertibles/1208_2013_morgan_3_wheeler_first_drive/
Charlie, Former Editor Morgan Owners Group - Great Lakes
Posts: 519 |
And now it's even road legal in California,albeit the authorities categorize the M3W as a motorcycle! Tadah! Highway Motorcycles Executive Orders - 2012
