Morgan Aero 8
5 members (JMD, JohnHarris, sospan, Hamwich, Ian Wegg), 264 guests, and 31 robots.
+8Rich 96
John V6 51
Topics49,899
Posts838,024
#101323 16/08/12 07:48 PM
scottie Offline OP
Has anyone had the same issues, the car has just had a new starter fitted got back home push starter button dead not even a click tried half dozen times nothing.
Left for half an hour went back started first push of button.
Went out tonight drove for about 40 minutes, turned off the engine went into garage to pay fuel, came out nothing, tried about dozen times still nothing. Waited 20 mins started.
Any one any ideas ?
Thermal cutout? Vapour lock? what you got?
2011 +4 'LB' Indigo Blue, Heron trim
Saab 9-3 1.8T Sportwagon
scottie Offline OP
That has just went way over my head
Sorry, I'm a numptie! Guess you have a series 1 Aero? Don't know them at all, is it a BMW V8? My Range Rover did the same thing at times...
Scottie,
I have not had this happen on my Series 1 but I looked at all the data on back problems in the Maintenance and Servicing bit of Talk Morgan. The post called issues and resolutions back in August 07 seems to cover your problem.
Car will not start with engine at certain temperature, fault was the immobiliser locked on.
The immobiliser unit slipped and touched the bottom of the fuse box causing heat soak. The car would start once engine and immobiliser had cooled.
Hope this helps
Dave
Hope this helps
Hi
I have the same issue and it appears that it is the starter motor is at fault . a known issue for series one cars . The replacement starter is in fact a modified LHD BMW /Bosch starter .Apparently a big job - at least 8 hours to fit !!
Mine doesnt work one in ten attempts . Much worse when hot ....If left it will get worse until it packs up so best to get it sorted if this is the issue
Mine is on order and my really helpful dealer is sorting me out -
2013 Plus 8
Aero S5 Build week 11
Mr Fezza
Mr Fezza
First thing to do with any starter issues is to check the fuses - this is generally where there is an issue to start with before any this else goes.
Beyond this then overheating is a definite potential cause - as previously mentioned if the immobiliser unit is not well shielded or has moved this can cause the issue.
Maxxed out!
Had the same on my old S1 some years ago. It was the fuse which had half fused..or similar. There was a factory mod to upgrade the fuse.. but I cannot remember from what to what now.. Have a look for it and put a bigger one in...
Phil Egginton
1979 4/4 4 seater
