9 members (meabh, Sloany, mph, John07, Ruut Bianchi, Ian Wegg, BLUE+4, TBM, MogOnTheMove),
298
Topics48,338
Posts812,948
Members9,203
Posts: 14,976 Likes: 1
Posts: 14,976 Likes: 1 |
I had a glass fuse recently that looked fine - but had failed - the cap had come loose and the connection lost with the fuse wire - visually looked OK - until I took it out in desparation and left one of the caps in the holder.....
Richard 1976 4/4 4 Seater
Posts: 28,415 Likes: 177
Posts: 28,415 Likes: 177 |
Hehe, I've had a number do that. Drill a tiny hole in each cap, feed new fusewire through from the end with the fixed cap, through the loose cap which you can then refit and solder wire to both caps - bingo, new fuse!
Blade fuses can appear OK, when they're not, too.
Sold L44FOR 4/4 Giallo Fly '09 Gen2 MINI Cooper ragtop '90 LR 90 SW
Not a bad plan - I also noted the fuse terminals coroding a bit so I found a new Lucas fuse holder on Ebay.
Then I learnt what I thought were moulding "features" (kind of holes in the holder body between the first and last fuses and those in the middle) were a vertical holder for spare fuses!
Small things....
Posts: 541 |
A visual check of modern fuses can totally miss a blown fuse (had that with "booty's" +4). An ohmeter is always best... But then you had to know how to use it Graham.  Ken.
Ken in Sweden - SM7CQY Mr BRUM - Morgan Roadster 2004 Series 1 in Royal Ivory
Yes, well I'd happily give lessons if anyone wanted to know how to use a multimeter - easiest done in a practical fashion of course - as you well know!!  Cheers,
For fuses use the continuity setting (diode check). It's the setting marked (normally) by a solid triangle with a vertical lie against one of the points. Mine beeps went there is a connection between two points, ie the two ends of a fuse.
Posts: 1,103 Likes: 2
Posts: 1,103 Likes: 2 |
Yes, well I'd happily give lessons if anyone wanted to know how to use a multimeter - easiest done in a practical fashion of course - as you well know!!  Cheers, Take you up on that one Graham, if you get down to Wheels in Winslow you can show me over a pint! I would also appreciate tips on using a Dremmel, I'm am positive I am not getting the full use out of all the attachments.
Keith
Car 54 - 'Le Mans 62' 4/4 Supersport OxMog Member (and associated with CranMog and SwanMog)
I'm at Blenheim this year Keith. Plan to be back at Winslow next year though...
Posts: 632 Likes: 6
Posts: 632 Likes: 6 |
I have also lost indicator lights once, but it was due to water ingress. They only worked when headlights were turned off. Next morning everything was OK again. Harald
Posts: 388 |
Hello Harald, my 2006 anniversary has the same fuse box card. It has not much in common with the reality.  The cigar lighter, both backlights and the sidelights share one fuse in reality. Keep mogging, Christian
2006 4/4 70th anniversary, 1985 VW 1200 50th anniversary, 1977 Vespa 50 Special, 2003 Vespa PX 200E
