5 members (banbury, JohnHarris, Image, Rastus, Gonze), 254 guests, and 30 robots.
+8Rich 99
Luddite 54
Topics49,905
Posts838,098
Page 8 of 12 1 2 6 7 8 9 10 11 12
South Wales Correspondent
+3
(especially since that stuff is notoriously difficult to get a good bead on)
Cheers
GLLHG
Don't know how it goes with the Roadster but with the Plus 4 fitted with aircon there are two small pipes that exit from the side of the cabin air intake airbox in the gap between the airbox and the cover in the photos. When the aircon is running a considerable amount of condensation runs out of those pipes and under the box mounted above the footwell. From there some of the condensed water drips through the grommet above the footwell. In over 8,000 km we have yet to have the car out in the rain but I suspect rainwater would also drip through the same grommet. I intend to put a neoprene gasket under the flange of the cover but leave the lowest point open so that any water that does enter can escape. Given the cover houses electronic components it needs to be dry inside.
Yes I will post my experience an photos as soon as I got my Roadster. I hope I can drive it before snow is falling…
Morgan Roadster 3.7
No aircon to worry about, just rain! As far as I can see, most of the water comes through the side louvres & arrives on said grommet. It then makes good progress through the grommet & on to the driver's ankle, via the throttle control. I found that some duct tape over the wiring loom/ grommet stopped the water, but didn't look very pretty, hence the cover.
Couldn't you extend the pipes so they discharge somewhere out of the way?
Ian
3.7 Roadster
4" Ruston Procter SD Tractor
1905 Merryweather steam fire engine
On the Plus 4, or at least the LH drive version, there is a cover on top of the footwell over the ECU. It is very close to the ends of the tubes but it may be possible to find something to do the job of draining the water away. The real problem is that if water from the aircon can enter in under the cover so can rain. One way or an other it is a problem that needs to be resolved.
Your work is too good for me to spot what you've actually done Ian!
When I get mine, I'll have to get a mod list from you.... Whilst I don't plan to take mine out in the rain, I probably will as its not going to be a garge queen.
+8 4.8
We have had such a dry summer that our car has done 8,500 km and still has not seen heavy rain. I think the next time it rains I am going to have to take it out just to find out where it leaks umbrella
Thanks for telling us how wonderful your weather has been wink
For those of us in the UK, it basically rained from the end of March to the end of August umbrella
We have, however seen the sun since the start of September
Long may it continue (though I suspect it won't) shades
Enjoy your Mog rain or shine and remember hood up, sidescreens out is great fun in the rain.
Bud
__________
2003 - 4/4
Bud
4/4 "Stanley"
Flattery will get you everywhere wink
Compare the first & last picture in my earlier post. In the first picture, to the left of the steering shaft & slightly above it is the grommet which allows the cables ( and the rain!) to go through the bulkhead. The new cover goes over the bunch of cables & the grommet.
Glad to hear you'll be using your car. I can never understand someone having a Mog & not driving it ooo
3.7 Roadster
You haven't seen tomorrow's forecast then?
A umbrella will only help you do a Mary Poppins from the looks of things...
I'm on a Vulcan tour tomorrow (Wellesbourne) - think I'll be going in the 90 - with added kayak laugh2
