3 members (Image, Jon G4LJW, RichardV6), 238 guests, and 31 robots.
+8Rich 95
John V6 52
Posts838,002
rockabilly john
Page 2 of 5 1 2 3 4 5
Neilda #108374 15/10/12 05:03 PM
I also use moly grease & the last Roadster did 30,000 miles on plastic bushes with no play up to the time it caught fire...
I do mine about every 1000 miles.
Neil, the first time I greased the suspension on my new Roadster I thought it must be a candid camera stunt! I kept pumping but nothing came out. I looked for a pile of grease on the floor: nothing. Then eventually, some came out. I don't reckon the factory put much in...
After that, the suspension & steering were much better, so don't give up on the grease gun!
Ian
3.7 Roadster
4" Ruston Procter SD Tractor
1905 Merryweather steam fire engine
shiremog #108381 15/10/12 05:31 PM
Neilda Offline OP
Hi Ian, having juuuust got my hands clean after a Mr Bean episode in the garage with the grease gun (don't ask) I'm not minded to tackle this again for a couple of days!
The good doctors at BHM told me that the new bushes feature some kind of 'rifling' (for want of a better expression) that enable the grease to reach the bottom better. Therefore it's not absolutely vital to grease the bottom nipple (snigger).
What's your routine?
I pumped as hard as I could until my wrists gave out - but had no idea if any was coming out. Can't type this without sniggering. My mind is in a schoolyard gutter this evening, sorry! smile
+8 4.8
Neilda #108388 15/10/12 05:55 PM
Hi Neilda, I found the greasing issue a bit of an issue when I got my car about a year ago. I realigned the nipples, using fibre washers as spacers, so that I could attach the grease gun without removing the wheels.
I bought a flexible tube to attach to the grease gun easier to put on take off.
And I use Nitrile gloves to keep my hand clean. This prevents me getting grease on the car/brakes etc.
I grease the bottom first, the clean off the excess and then I put grease into the top nipple and then clean off the excess.
What you need is a friendly owner to show you how to do it and then you will be fine.
Ian
Neilda #108389 15/10/12 05:56 PM
I'll ignore the schoolboy smut oldgit
Sounds as if none's going in. As suggested in another post, it may be worth taking a nipple out, put it on the grease
gun & see if any comes out. Having said that, I was surprised at how much grease went in mine. Next time should be back to normal ( about 5 pumps )
I jack the front up, set it on a couple of axle stands then grease the lower nipples from underneath. I then do the upper ones from behind the wheel after turning to full lock ( the old Roadster didn't have the top nipples, more work!) . Shouldn't need to take the wheels off.
Ian
3.7 Roadster
shiremog #108392 15/10/12 06:09 PM
Neilda Offline OP
Since having the wrench, the wheels come off easily.... So I don't find that a chore.
Hmmmm. I shall have to persevere.. I may invest in a different gun too. The pistol grip is tiresome.
Thanks for the replies. Appreciated.
+8 4.8
Neilda #108396 15/10/12 06:21 PM
My handbook says every 1,00 miles - but I tend to do them about every 8-9 hundred to make sure. My nipples faced the wrong way originally but were persuaded to turn by judicious use of a spanner - very light pressure was used - so did not need to put in a washer
Neilda #108484 16/10/12 05:12 PM
Green & Grown Up
Green & Grown Up
Originally Posted By Neilda
- the near side nipple is facing in towards the car, so it's impossible for anyone other than a contortionist to reach.
Begs the questions,
How did the factory get grease into it?
When in the process do they grease a new unit during build?
How much Grease do they put in that first time?
What Brand of Grease does the Factory Use for Sliding Pillars?
I have one of those old BP Morgan Lubricating Charts. It specifies BP Energrease L2 Wheel Bearing Grease
Rolls Royce / Bentley equivalent chart lists :-
BP Energrease L2
Castrol LM,
Duckhams LB 10,
Esso Multi-purpose,
Gulf Crown No. 2 EP,
Mobil MP,
Shell Retinax A )
I use 'Comma High Performance Bearing Grease (Heavy Duty Lithium Complex Grease)' idea
Frank
Frank 4x4 #108563 17/10/12 03:18 PM
Neilda Offline OP
With the wheels off, the inward facing nipple isn't a problem to reach....
+8 4.8
Neilda #109174 23/10/12 07:08 PM
Neilda Offline OP
Well I got my self an air powered grease gun and have now greased the wheels.
The bottom nipples look impossible to reach, so I didn't use them. But from the top I was able to get enough grease at the top and can see it appearing at the bottom. Which I assume is the signal that it's time to stop!
Is it bad practice not to grease from the bottom?
I'm hoping to take it for a drive tomorrow. smile
+8 4.8
Neilda #109176 23/10/12 07:28 PM
The good thing about this thread, is when 'er indoors asked me how we TMers seem to find to so much to talk about, I was able to tell her "We mainly talk about nipples and lubrication"
Giles. Mogless in Paris.
