8 members (Lance, M3WMW, SEG, cerealsurfer, +8Rich, Hamwich, stumog, Black Adder),
212
48
Topics49,909
Posts838,126
Posts: 22,371 Likes: 354
Posts: 22,371 Likes: 354 |
I started out at 3/3 with my AVO's, but two up it would still bottom out at the rear when booting it on an uneven road, so now I'm on 4/4 clicks.
Posts: 27,846 Likes: 764
Posts: 27,846 Likes: 764 |
Miller's have just fitted Cerealsurfers secondhand Sapx shock I bought on TM. All I can say is they are big improvement over my old Konis.
Posts: 4,612 Likes: 15
Posts: 4,612 Likes: 15 |
John - What type of difference?
Much smoother in general with far less bottom out of the shock.
Posts: 1,112 Likes: 17
Posts: 1,112 Likes: 17 |
I have Avo front shocks which I fitted in 2013 and have now done 20k. I notice oil misting around the shock tube. Is this a sign of them failing? Is there a way to tell if they need replaced or not? They are Avo (Rutherford by New Elms)
Thanks in advance Will
Posts: 8,702 Likes: 416
Posts: 8,702 Likes: 416 |
Sounds like they are starting to fail Will. Do they still work and respond to increased setting?
I haven’t changed the setting since I fitted them.. what’s optimal?
On mine tweaking them up a couple of clicks at a time then driving on a similar stretch of road I found a point where the front stopped moving up and down so much. For the first few hundred yards it seemed the suspension had become too firm but then after a mile or two I realised the ride was actually more comfortable because of such. I called it the sweet spot as it was so well defined. You can always back off a click or two to prove the point. YMMV
Posts: 5,442 Likes: 133
Black Rat Charter Member
Posts: 5,442 Likes: 133 |
You can get them refurbished I believe.
Posts: 6,676 Likes: 441
Posts: 6,676 Likes: 441 |
You can (they're just up the road from me) https://www.avouk.com/services/
