0 members (),
251
Topics49,904
Posts838,088
Posts: 28,911 Likes: 354
Posts: 28,911 Likes: 354 |
Thought as much. I take it your potential classic wasn't one of P.M.'s £35k+ models then?
Posts: 8,646 |
I fail to understand the logic of NCD being on a per contract basis. Surely it should be about the risk you pose as a driver, If anything if you should get even more discount, if you have more cars you drive each one less.
Giles. Mogless in Paris.
Posts: 14,009 |
Lol...not quite Graham! Giles...I totally agree with you. I've run a multi motorbike policy in the past and they take the view that you can only ride one at a time. But then the UK car insurance market is one great rip off with costs of spurious claims spiralling out of control.
Posts: 22,371 Likes: 354
Posts: 22,371 Likes: 354 |
Very nice Elise........................... I think the massive excess is to cover the cost of a clam replacement - easily damaged, and allegedly about that cost to put right. Clam damage can be very superficial and this way, you would probably have it repaired. Tub damage, according to the forums usually leads to a write off. It would make a nice home rebuild project on a new tub though.......
I can see it now that I'm home... Very nice Richard  There are some here that will tell you white cars are faster - do the leaves help???  Cheers,
Posts: 1,558 Likes: 5
Posts: 1,558 Likes: 5 |
Very nice Elise........................... I think the massive excess is to cover the cost of a clam replacement - easily damaged, and allegedly about that cost to put right. Clam damage can be very superficial and this way, you would probably have it repaired. Tub damage, according to the forums usually leads to a write off. It would make a nice home rebuild project on a new tub though....... Cor blimey, you're a ray of sunshine,  all clam damage and tub write offs  more to the point have you got your tape measure out and will it fit up your drive?
It will fit, with a bit of vaseline. Next hurdle is insurance, but that can wait until nearer the time. You're a bad influence.
I thought there was also a problem with the chassis - once damaged it's toast?? RV8gone then Dave?
Posts: 7,363 |
Good bye Roadster, hello Lotus Elise S I'm not sure I can believe this, if ever somebody epitomised a Mog owner I thought it was you Richard! I wish you well with your new car and look forward to reading a detailed comparison with the Roadster. Can we open a book on when you'll be back in a Morgan?
Brian
1970 Morgan Plus 8 - Moss Box (Indigo Blue) 2014 Morgan SP1 (Rocket Red) 2015 Morgan Plus 8 (Rocket Blue)
