0 members (), 110 guests, and 153 robots.
+8Rich 101
John V6 66
2001 +8 Temperature gauge
by AlanB - 16/09/26 07:39 PM
Longest owner?
Suspension upgrades
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
First Morgan as it is now
by Strathaven, September 15
Topics49,921
Posts838,290
Smed., Spanner Juggler
Originally Posted By Malcolm T
Graham is right I think about the box unless it's been altered, here's a helpful link which shows the clutch setup and deals with potential wear points and improvements.
http://www.gomog.com/allmorgan/plus4clutch.html
Don't know about the availability of parts and would appreciate some feedback if you go ahead
The GOMOG article is written by Mike Miles (A Professional Engineer) who lives in Portland, Oregon. I know Mike and I have re-read the article in GOMOG. Mike is right on. Mike has a lot of experience regarding the drive train of the TR powered +4's. Be sure to thank Lorne Goldman for including Mikes article in "GOMOG".
Button
my TR4 clutch is operating near the top of the pedal ie depress about 1/2 inch to disengage clutch ...I would like it to operate lower down or halfway through the pedal travel...which adjustment please...can I get to the adjustment under the car or do I remove the drive tunnel?
Triumph Herald 1969 13/60
Morris 1970
Here's the link again. The adjustment is from under the car and the adjustment rod 11 has opposite threads on each end so once you release the lock nuts you can rotate it to lengthen or shorten it.
https://www.gomog.com/allmorgan/plus4clutch.html
Malcolm T
1966 +4
1957 TR3
1963 TR4
1983 LR 110
1985 Robin Hood 2.0l
