8 members (RichardV6, Sir Percival, Burgundymog, TBM, KLASG, moggywills, Bishmog, Colin_Mackay), 215 guests, and 52 robots.
+8Rich 83
Luddite 50
Posts837,944
Page 3 of 7 1 2 3 4 5 6 7
Gambalunga #121258 30/01/13 08:03 PM
Vspec Offline OP
Goose grey smile
Thanks for looking Asbo and Jmd. something is definitely wrong then. Car is tucked up for the night now, I'll try it afresh tomorrow.
MikeMTW #121261 30/01/13 08:17 PM
Do you have a double bolt on the other side of the steering wheel? ie the one you can't see in your photo? I thought that the cars are delivered with the release disabled now (can't confirm that myself). So it may be that it was simply not fitted correctly. If you have a double both, this is your issue...
In theory, once the wheel is in the correct position, you push it in to where you are in your second photo. On your first photo, you can see the 'flat' section. Make sure that this is lined up with the 'flat' section inside the wheel.
Then pull back again, and push, this releases the outer collar to lock. But it looks like you can't pull it back anymore...
I am really hoping that its just getting it lined up correctly! Good luck! confused
MikeMTW #121263 30/01/13 08:25 PM
Hello all
This thread is certainly interesting to me as I am pretty sure that our 3 wheeler is a build buddy of Vspec's (I saw them together in a picture a few weeks ago). Looking at the pictures above and comparing with Mike's, it seems that the newer wheel is a bit thinner and so maybe the bolts protrude a bit more - there also appears to be an additional washer. Could this be preventing the mechanism from working?
Just a thought.
Looking forward to our arrival. A little hiccup with the dealer has slowed things down ....
MikeMTW #121264 30/01/13 08:41 PM
Vspec Offline OP
I think you're probably onto something with the bolts Mike. There's no double one, but one of them is much shorter than the other 2. These 2 prevent from pulling back the mechanism unless it is lined up so that they fit through the holes. I thought it was all moving ok as long as I did this... Maybe not.
Tomorrow I might remove the wheel from the boss/collar - thus eliminating the bolts from the equation - and see if the collar fits on its own. If that works then the bolts need shortening.
Vspec Offline OP
Originally Posted By JonnyEnglisch
Hello all
Hi Jonny, which picture was that? If it was the pic of Berts dark green one, is yours the green or red one next to mine?
Vspec #121267 30/01/13 08:49 PM
Yes it was Bert's pic. Pretty sure that ours is the red one - brown leather, lhd. Hopefully it will be on it's way to us very soon.
Vspec #121270 30/01/13 08:53 PM
Ok,
The bolts should line up exactly with the holes. If you can rotate the collar, this could the issue, BUT you have a new style steering wheel so it could be different!
I hope you can see that the bolts are lined up! The camera angle makes it look like they are not, but it is a perfect 'fit'.
Simply pressing the collar down should allow the long bolt to pass through as below...
Vspec Offline OP
I have that picture saved grin2 looks to have black roll hoops? Looking forward to pictures when you get it
MikeMTW #121276 30/01/13 09:03 PM
Vspec Offline OP
Ok,
Thanks Mike. My collar rotates. Yours doesn't? Strange as I think they are the same. Does yours have a sticker on it? The steering wheel itself shouldn't make any difference I wouldn't have thought
Vspec #121278 30/01/13 09:07 PM
Nope, the collar is fixed. The sticker is from lifeline which is a fire extingusiher company.....
