5 members (RichardV6, Vansrv6, mph, vbalddave, Laurens), 275 guests, and 27 robots.
+8Rich 102
John V6 64
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
Topics49,915
Posts838,218
MossyfromNZ
Parna Offline OP
Hi, I'm new to the forum, I own a plus 8, 2001 3.9l, bought last Sept, and have driven some 500 enjoyable miles in it so far, have had the not uncommon stop light switch failure, but other than that the car is behaving very well.
One thing that does bother me however is the gruff noise from the engine when starting from cold, and its not just the tappets rattling prior to the hydraulics taking up the slack. The Morgan dealer says it's just a characteristic of this engine, once the engine has warmed up the noise seems to dis appear. The car was stored for some 4- years prior to me buying it, and I wondered if there could be an issue with the cat's has anyone come across this with the plus8, hoping the above makes sense.
Parna Offline OP
Adrian
Welcome Parna!
Ken in Sweden
Ken in Sweden - SM7CQY
Mr BRUM - Morgan Roadster 2004 Series 1 in Royal Ivory
Any more info on the noise?
Is it a top end rattle?
What's the mileage on the engine?
+8 4.8
Parna Offline OP
Hi Ken,
Thanks for the welcome, ref the noise, not sure really if it's a top end rattle, it may be,! Car has done 26,500 miles approx
Parna Offline OP
To add to the noise description it's like a rumble type noise, but as mentioned earlier seems to smooth out when engine is up to temperature so to me is not really an engine wear issue.
Cheers Adrian
Hi Parna,welcome to the forum.
Ian
Parna Offline OP
Hi plus 4,
Thanks, I'm pleased I found this forum, lot's of friendly helpful people.
Parna
The Rover V8 is susceptible to main bearing rumble. When I had this engine in an MGB, I always did the first churn of the starter without choke, just to prime the oil feed. If I didn't do this it would rumble from the bottom end for a few seconds.
My 3.9 +8 of similar age also rumbled and also occasional high pitch squeal from top end scared. This was always after standing for 2+ weeks in garage or first start up from cold after a long (100m+) hot journey. Seemed to be lack of oil in the first 3/4 seconds then all was ok. Regular oil changes ensured that at least the best oil was being used and I lived with it. drive
