Posts837,991
Posts: 413 |
Steering column problems I have found that the bearings on the steering column are completely use, there is a bearing at the bottom and a bearing at the top    I have found solution to repair the bearing at the top Thanks to Lorne: http://www.gomog.com/allmorgan/steeringcolumnbearing.htmlI have bought the kit from John Worrall, Heart of England  And for the bearing at the bottom i found on the on German Morgan forum an idea with Self-aligning ball bearings 2205  i have constructed 2 flange where the bearing is stuck between    the telescopic shaft on the bottom has to be adapt on a engine lathe for the bearing diameter 25mm and the end parts has to be cut  And here the result
Don't Worry, Be Happy Morgan 4/4 1985 2,0 Zetec BMW R1200 GS Triumph TR140
Posts: 2,361 |
Looking very good mate, hows does it now perform and feel?
Instagram - WilliamsMotorsportuk - Lawrie Mills(Chunkylozza) Youtube - ChunkyLozza
Posts: 1,597 |
For goodness sake, put it all back together again before you forget where those bits came from. Having said that, it does look like you have everything under control.
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Good work.
I just replaced my whole steering column as I Ould not source the lower bearings. I got a fully reconditioned one from Brands Hatch Morgan. No link just a satisfied customer.
Richard 1976 4/4 4 Seater
Posts: 28,909 Likes: 354
Posts: 28,909 Likes: 354 |
Excellent, thanks for sharing the information and
Posts: 413 |
1.test in the road,
Posts: 413 |
Yesterday 100km on small road,  feeling great aim happy of my job
Posts: 2,515 Likes: 1
Posts: 2,515 Likes: 1 |
Great idea! What's the size of the bearing at the bottom?
1972 4/4 2 Seater
Posts: 413 |
