10 members (JohnHarris, JMcL, IcePack, John V6, Burgundymog, RichardV6, Vansrv6, bmgermany, Luddite, Colin_Mackay),
288
Topics49,899
Posts838,029
Posts: 19 |
Hello There, There seems to be different schools of thought on this, I have have used Lithium grease on starters and it seems to help function as surprisingly very little muck gets into that area of the bell- housing. Regards, Charles
Posts: 19 |
Hi Dave earlier cars like this 1964 have starters with separate Solenoid, not a pre- engaged unit, I had a look at the ring gear it looks ok My mind is getting boggled rapidly with this! Regards, Charles
Posts: 5,013 Likes: 32
Posts: 5,013 Likes: 32 |
Hello Jack, I haven't heard of power-lite where can they be sourced from? Earth straps etc all checked, cleaned and tightened. regards, Charles http://www.holden.co.uk/displayproduct.a...p;pCode=081.320I can't think of any reason why you're getting through starter motors - other than as already suggested, it was a poor batch.
+8 4.8
Posts: 19 |
Hello Jack, Thanks for that link, I'll check them out, Regards, Charles
Posts: 8,015 Likes: 1
Posts: 8,015 Likes: 1 |
Here is a bit info I purchased mine 23-07-2010 from AES Electric Supplies Ltd Granville House 11 Cross Sreet Tenbury Wells Worcesrershire WR15 8EF 01584 819552 www.autoelectricsupplies.co.ukthey sent out a RAC-410 it was the wrong one so they picked it up with my original and built a one to match RAC-110A high torque . When it starts up it gives a Whizz sound . It cost me in total £158-63. Mathew is the chap in charge . Just started it the other day after a month and it started first time . uote=greenmachine]Hello Jack, I haven't heard of power-lite where can they be sourced from? Earth straps etc all checked, cleaned and tightened. regards, Charles [/quote]
Posts: 19 |
Thanks Jack, They are closed till Monday but I will call them then for availability etc. Regards, Charles
Posts: 168 |
I don't mind being shot down for this, here goes, I just seem to remember being advised not to grease the bendix on a starter motor. Agreed - dirt and clutch plate dust sticks to the grease and makes the problem worse. But I remember a squirt of WD40 on the starter bendix of my Triumph Vitesse worked wonders when I had a similar problem years ago. I think powdered graphite or MoS2 was the recommended lubricant.
Fjemog
1993 Plus 8
Posts: 167 |
That it is OK on the first crank, but not the second reminds me of a problem I had years ago with a rebuilt starter. The rebuilder used a wire size that was too small in the armature, and as a result, when the starter was bone cold it would crank OK for a few seconds until the resistance rose in the windings, after that it would not develop enough power to crank. This also caused the drive pinion to remain engaged.
'65 +4 four seater
