5 members (Strathaven, Scrambledsignals, Morganmike, bmgermany, M3WMW), 235 guests, and 24 robots.
+8Rich 99
John V6 57
Topics49,909
Posts838,126
Has anyone had or seen this and is it recommended? Allon White trim the inside of the sidescreen panel to match the upholstery. They say it gives the car a more finished look and reduces draughts significantly.
http://www.allonwhite.co.uk/Morgan-Coach-Trimming/Morgan-Interior-Trim/Sidescreen-Inner-Panels/
David
2020 Roadster 3.7 Dove Grey.
I guess much would depend on how you're going to use your Morgan. Mine spends most of its time with the roof and sides off.... So it's probably not worth it for me.
But for someone who is going to use the car in all weathers, it looks a neat idea.
I assume the sides will take no longer to take off or install.
+8 4.8
I don’t think it makes a difference to installation times, Neil. My dealer says they look really good and I do want to use the car in all weathers and envisage a reasonable amount of top up driving. Could be worth looking at.
David
Previous owner of my +4 had them done when he went for their Easy-Up hood. They give a very neat finish to the sidescreens.
Probably worth doing then David.... It'll be like a gentlemans club in there! smile
+8 4.8
Sounds like a recommendation wink
I’ll have Port and cigars in there as well toff
David
does it stop you resting your elbow on the top of the door with sidescreens on? That's vital space...
Nick
I had mine done by Steve Simmonds, make it look much more finished and make no difference to the operation at all. A very worthwhile (cosmetic) improvement in my view. But then I also added walnut liners to the inside of the door pockets and chrome door lock covers, a walnut gear knob and a walnut (metal painted to look like walnut)steering column cover from Uncle Melvyn, just because I think they improve the look.
Steve L.
1996 Plus 8
N22 MOG
+1 I have the Simmonds version. Works well and loks good.
Mine too, they look very smart especially with walnut door cappings. They must reduce draughts too but as I never drive covered up I can't vouch for this.
Andrew
