3 members (Image, ITP, Pittsartist), 233 guests, and 26 robots.
+8Rich 96
John V6 51
Topics49,901
Posts838,046
Hello There,
There seems to be different schools of thought on this, I have have used Lithium grease on starters and it seems to help function as surprisingly very little muck gets into that area of the bell- housing.
Regards,
Charles
Hi Dave earlier cars like this 1964 have starters with separate Solenoid, not a pre- engaged unit, I had a look at the ring gear it looks ok
My mind is getting boggled rapidly with this!
Regards,
Charles
Originally Posted By greenmachine
Hello Jack,
I haven't heard of power-lite where can they be sourced from?
Earth straps etc all checked, cleaned and tightened.
regards,
Charles
http://www.holden.co.uk/displayproduct.a...p;pCode=081.320
I can't think of any reason why you're getting through starter motors - other than as already suggested, it was a poor batch.
+8 4.8
Hello Jack,
Thanks for that link, I'll check them out,
Regards,
Charles
Posting Desperado
Posting Desperado
Here is a bit info
I purchased mine 23-07-2010 from AES Electric Supplies Ltd
Granville House
11 Cross Sreet
Tenbury Wells
Worcesrershire
WR15 8EF
01584 819552
www.autoelectricsupplies.co.uk
they sent out a RAC-410
it was the wrong one so they picked it up with my original and built a one to match RAC-110A high torque . When it starts up it gives a Whizz sound .
It cost me in total £158-63.
Mathew is the chap in charge .
Just started it the other day after a month and it started first time .
uote=greenmachine]Hello Jack,
regards,
Charles [/quote]
Thanks Jack,
They are closed till Monday but I will call them then for availability etc.
Regards,
Charles
Originally Posted By Wirewheel
I don't mind being shot down for this, here goes, I just seem to remember being advised not to grease the bendix on a starter motor.
Agreed - dirt and clutch plate dust sticks to the grease and makes the problem worse. But I remember a squirt of WD40 on the starter bendix of my Triumph Vitesse worked wonders when I had a similar problem years ago. I think powdered graphite or MoS2 was the recommended lubricant.
Fjemog
1993 Plus 8
That it is OK on the first crank, but not the second reminds me of a problem I had years ago with a rebuilt starter. The rebuilder used a wire size that was too small in the armature, and as a result, when the starter was bone cold it would crank OK for a few seconds until the resistance rose in the windings, after that it would not develop enough power to crank. This also caused the drive pinion to remain engaged.
'65 +4 four seater
