5 members (SailingTom2, JohnHarris, IcePack, Stevo666, +8Rich), 233 guests, and 27 robots.
+8Rich 102
John V6 65
Suspension upgrades
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
First Morgan as it is now
by Strathaven, September 15
Topics49,918
Posts838,255
Smed., Spanner Juggler
#134428 04/05/13 10:40 AM
We have a 1994 Morgan 4/4 1.8 Zetec. Original front suspension,
We only use it for pleasure and my wife is finding it harder to steer. Has anyone fitted the PAS power steering unit?
I'm sure the die hards will consider even considering this as out of the question. All the other options to the front suspension are just too to confusing!
Your comments or advice greatly received!
Some discussion here....
PJB Offline
John, firstly I suggest that you check the condition of the king pin, bushes and friction damper which is a bronze plate squeezed between the spring and the top of the hub. These all can have a significant effect on the steering effort, dismantling will be required for a complete inspection, but this is not a long job.
The friction damper assembly should be lightly lubricated, but too much lube and you might get shimmy. Later cars, 2008 onwards I believe, used a ball thrust race to significantly reduce steering effort. This is not a straight swap as main spring length has to change too and shimmy will need controlling with a hydraulic steering damper, see later.
One of the other design features that causes the steering not being as light as it could be is that the rebound spring (under the hub) is often compressed thus rubbing on the underside of the hub as you turn the steering. Check yours, free length should be 86mm. The rebound spring can be cut so that it is just kissing the underside of the hub at static ride height, this will soften the ride and reduce steering effort, but will increase ride height by about 20mm.
As has been publicised a few times, the SUPLEX Front Suspension Refinement System will actually reduce steering effort as well as providing better ride and handling.
https://sites.google.com/site/morganatica/suspension/springs-progressive-rising-rate
NB IF you do replace the steering friction damper it is often wise to also fit a hydraulic steering damper to control shimmy.
https://sites.google.com/site/morganatica/70-modifications/vw-hydraulic-steering-damper
Electric PAS will no doubt reduce steering loads with your standard system, but it should be in good condition first.
I hope this helps - regards PJB.
I hope this helps.
PJB #134445 04/05/13 01:07 PM
What size steering wheel do you have fitted?
If it is a 14", then you would be amazed the difference in fitting a 15"
Bud
__________
2003 - 4/4
Bud
4/4 "Stanley"
As PJB says, first thing is to make sure everything is set up properly and fully greased. It's worth checking your tyre pressures are set right too. I can heartily recommend the Suplex front suspension upgrade, it does indeed make the steering lighter.
And like Mr B, I can recommend going up a size in steering wheel.
