6 members (Beard, John V6, bmgermany, Julian BB, linklaw, marshalben), 153 guests, and 68 robots.
+8Rich 102
John V6 67
Goodwood
My 4/4 as it was in 1975
US Cars - Metric Threads?
by Paul F - 17/09/26 08:29 PM
Nice hardtop
International Morgan Day
by Deejay - 17/09/26 02:45 PM
2001 +8 Temperature gauge
by AlanB - 16/09/26 07:39 PM
Longest owner?
First Morgan as it is now
by Strathaven, September 15
Topics49,928
Posts838,436
Page 2 of 8 1 2 3 4 5 6 7 8
Gambalunga #134549 05/05/13 09:43 AM
PJB Offline
I will need to get permission from SUPLEX UK Ltd first, if OK the SUPLEX Front Suspension Refinement System instructions in PDF will go on:- https://sites.google.com/site/morganatica/suspension/springs-progressive-rising-rate on Tuesday 7th May. Regards PJB.
PJB #135334 10/05/13 08:55 PM
Any update on the availability of fitting instructions. It would really make the case for purchasing for own fitting if it is clear on what has to be done. I see that nothing has been added to Morganatica site.
Keith
minikeefy #135373 11/05/13 08:15 AM
PJB Offline
The latest SUPLEX installation instructions have been added to:- https://sites.google.com/site/morganatica/suspension/springs-progressive-rising-rate?pli=1
These are in the form of PDF and are effectiely an attachment to that page that can be read or printed.
This is with permission of SUPLEX UK Ltd. Regards PJB.
PJB #135380 11/05/13 09:16 AM
Thanks - personally I found it very intersting and informative.
PJB #135421 11/05/13 12:31 PM
Thank you, Peter, for posting the Suplex instructions.
Best wishes, Gerry.
Gerry
GerryWal #135793 13/05/13 06:02 PM
Thank you Peter.
Having fitted the kit I can thoroughly recommend the springs. I have now done about 500 miles and have not bottomed out over speed bumps or had any issues whatsoever. The instructions were straight forward when you start taking the suspension apart. The reassembly is easier, as there is no load on the spring, and the adjusters allow you to balance the two sides and get the height right.
The handling inspires confidence.
I have no connection with Suplex. I am self taught but have a lot of experience taking apart and rebuilding Morgans.
Titus
2007 +4 4 seater
2017 Mini Cooper
2007 VW Camper
1996 Honda TRX300
2012 Husqvarna 216
titus #136278 17/05/13 06:14 AM
I just heard from Borghi in Milan who has fitted the Suplex kit for me. He has said that on the road test the was a noticeable improvement with the front suspension more compliant.
Certainly there are some rough bits of road around the back streets of Milan but I don't imagine he had a chance to try it in some hard cornering smile
The weather here is terrible at the moment. In the last month we have had almost constant rain with only 3 or 4 really sunny days. To top that off we have been hit by an example of Murphy's Law in action.
The express-way road along the lake passes through a lot of tunnels, due to geological subsidence one of the southbound tunnels has been diverted to the northbound tunnel making it one lane each way. Last Friday night they discovered subsidence in the northbound tunnel so now both tunnels are closed for maintenance. For the next 6 weeks, at least, all traffic, including hundreds of heavy vehicles a day, must pass along the lakeside road and through the various small villages and small tunnels. They have had to make various sections alternating one-way to avoid two heavy vehicles getting jammed and blocking the road. Delays are measured in hours.
All this is to say I am at least waiting till it stops raining before going to collect the car frown
Gambalunga #136283 17/05/13 07:32 AM
Peter, Murphy has obviously left us temporarily for north Italy!!!! Sorry to hear of your troubles. I hope you get to collect your car soon!!
Cheers!
Robbie
2021 Plus Four -- Helga
211-WX-1433
Robbie #136285 17/05/13 09:01 AM
I just checked the forecast. For the next two weeks only next Wednesday and Thursday are given as fine. Minimum temperature will be 9 degrees, that means the mountain tops will probably get snow! We lit the fire last night and I am sure we will do so again in the next few days. Unbelievable frown Looks as though the sun will start shining from the 1st of June.
You have to feel sorry for the guys doing the Mille Miglia umbrella
Gambalunga #136319 17/05/13 02:35 PM
Good (and unlucky) news Peter.
