8 members (John V6, Julian BB, linklaw, marshalben, Socalm3w, Stephen888, Rog, bmgermany),
164
Goodwood
Topics49,928
Posts838,436
Posts: 1,103 Likes: 2
Posts: 1,103 Likes: 2 |
Any update on the availability of fitting instructions. It would really make the case for purchasing for own fitting if it is clear on what has to be done. I see that nothing has been added to Morganatica site.
Keith
Car 54 - 'Le Mans 62' 4/4 Supersport OxMog Member (and associated with CranMog and SwanMog)
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Thanks - personally I found it very intersting and informative.
Richard 1976 4/4 4 Seater
Posts: 2,814 |
Thank you, Peter, for posting the Suplex instructions. Best wishes, Gerry.
Gerry
Posts: 517 |
Thank you Peter. Having fitted the kit I can thoroughly recommend the springs. I have now done about 500 miles and have not bottomed out over speed bumps or had any issues whatsoever. The instructions were straight forward when you start taking the suspension apart. The reassembly is easier, as there is no load on the spring, and the adjusters allow you to balance the two sides and get the height right. The handling inspires confidence. I have no connection with Suplex. I am self taught but have a lot of experience taking apart and rebuilding Morgans.
Titus
2007 +4 4 seater 2017 Mini Cooper 2007 VW Camper 1996 Honda TRX300 2012 Husqvarna 216
Posts: 14,751 Likes: 158
Posts: 14,751 Likes: 158 |
I just heard from Borghi in Milan who has fitted the Suplex kit for me. He has said that on the road test the was a noticeable improvement with the front suspension more compliant. Certainly there are some rough bits of road around the back streets of Milan but I don't imagine he had a chance to try it in some hard cornering  The weather here is terrible at the moment. In the last month we have had almost constant rain with only 3 or 4 really sunny days. To top that off we have been hit by an example of Murphy's Law in action. The express-way road along the lake passes through a lot of tunnels, due to geological subsidence one of the southbound tunnels has been diverted to the northbound tunnel making it one lane each way. Last Friday night they discovered subsidence in the northbound tunnel so now both tunnels are closed for maintenance. For the next 6 weeks, at least, all traffic, including hundreds of heavy vehicles a day, must pass along the lakeside road and through the various small villages and small tunnels. They have had to make various sections alternating one-way to avoid two heavy vehicles getting jammed and blocking the road. Delays are measured in hours. All this is to say I am at least waiting till it stops raining before going to collect the car
Posts: 3,482 Likes: 42
Posts: 3,482 Likes: 42 |
Peter, Murphy has obviously left us temporarily for north Italy!!!! Sorry to hear of your troubles. I hope you get to collect your car soon!!
Cheers!
I just checked the forecast. For the next two weeks only next Wednesday and Thursday are given as fine. Minimum temperature will be 9 degrees, that means the mountain tops will probably get snow! We lit the fire last night and I am sure we will do so again in the next few days. Unbelievable  Looks as though the sun will start shining from the 1st of June. You have to feel sorry for the guys doing the Mille Miglia
Good (and unlucky) news Peter.
